Question about Mitsubishi Televison & Video
1 Jan., 2011 Hi Fix It Representative: We have an old Mitsubishi 38 inch TV - model cs-313050. It will no longer turn on properly. When the power button is pressed on, the green light above the button will light up, and the sound of a click can be heard in the back of the TV. After about two seconds, another clicking sound can be heard and the green light above the power button turns off. The screen shows no lighting activity at all, nor any audio. Just a few minutes before this happened, we could get the screen to turn on, but it would only display a thin horizontal light line amidst the background of black. The audio would come on. We've tried resetting it with the audio reset button, unplugging the tv for a while and plugging it back in, but the TV will no longer work. Can you tell us what to do to fix this problem? Sincerely, Gary Woloshyniuk Sherwood Park, Alberta
  • daniel_wolos Jan 04, 2011
    no the solution was incorrect
  • 597 Answers
The problem with this television is that the lamp is bad, you need to replace the lamp of the television and it will be in good condition once again. To replace the lamp, you will have to get the appropriate screwdriver, then you unplug the television for about 6 hours so the high voltage in it will dissipate, because, television stores current in it. Then you get a cup to put all loosed screws in,then you turn to the back of the television, then check the lamps compartment, then you unscrew it open, turn off the lamps switch, then you unscrew the screw that is holding the lamp together, then you remove the lamp, assess it and replace it with a new one.
After doing that, replace the t-con board of your television also, it is in the upper middle of the main board of the television, replace it also before reassembling the television.
Check all boards on the television for bad capacitors also before reassembling the television back together, in order for ou not to loosen the television more than once.
If you are not familiar with such electrical activity, i will strongly advice you seek the assistance of a friend that can do such or a neighbor to assist you with this.
That should do the job for you.
Take care and good luck.
Happy new Year!!!!!!!
Posted on Jan 02, 2011
  • Mitsubishi Master
  • 3,267 Answers
This model suffers from vertical failure associated with a defective cap in the power supply.
A known failure mode and a kit is available from Mits to overcome this problem.
There is also another problem associated with the horizontal driver transformer.
You would be best advised to unplug the set and have it serviced before the CRT's are ruined from repeated attempts to turn it on.
There will also be quite a number of leaky caps in different areas of the circuits that will need replacing to circumvent future failures.
Mitsubishi tv 32 inch model number cs40505 won't turn on
Check its power regulator board. Check fuse. replace it as card basis, if found irrepairable.
Jun 14, 2012 | Mitsubishi CS-40505 TV
Where is a manual for a mitsubishi CS-31205 tv?
The manual for Mitsubishi TV model CS-31205 can be found by clicking the link below (Although the link says "CS 31305" , other models such as CS-31205, CS- 31309, and CS-31304, will use this guide as well)
Download Mitsubishi CS 31305 Owner Manual
Available for download (and offline viewing) in PDF format with a very short registration, or bookmark in your browser, and utilize online.
Or click below to visit the very useful website (the library is large, yet easy to use).
ManualsLib Makes it easy to find manuals online
(*just read this 2 year old question today- hope the OP found resolution)
May 25, 2012 | Mitsubishi CS-31205 TV
1996 mitsubishi 40" tv has a black screen and
no pic at all usiually means the the heater element in the picture tube it self is burned out. Also there could be a problem with the internal power supply that gives electricity to the heater element. These are all thing the cunsumer cant fix. You either need to trust ONLY a certified Mitsubishi TV repair man, or replace the TV.
I know it's not great news, but if this advice helps, please give me a good rating.
Jun 30, 2011 | Mitsubishi CS-40505 TV
Actually the model is cs-313050. its quite old. the problem is that the tv won't work in the way that when you turn it on (it won't even turn on anymore) there is nothing but a white or blue lineright in...
you didn't mentioned if it is a horizontal line but i think it is.
It seems that you have a faulty vertical I.C. that scan vertical line.Because you it is defective you've lost the vertical scanning thats why you have only a horizontal line on the screen.
You will confirm it by powering on the unit with your cable signal present.When the sound is present on every channel it is confirm that you have a problem on the vertical section. You must look for a qualified technician to solve the problem....
Jan 02, 2011 | Mitsubishi CS-40503 TV
Model CS- 40307 40 inch Mitsubishi TV will not turn on
continue to push power button until light turns green. verie rate of push and hold
Jul 15, 2009 | Mitsubishi WS-65819 TV
My 10 year old 55 inch Mitsubishi rear projection shuts off.
The main board/switch is worn to the point it will not work anymore after a while, I been in the business for years, These are wonderful TV's, yes there are replacement parts but a quick fix your looking for here will be unsuccessful this is the reason I am providing my advice and take a chance on the rating your going to give me. Try www.ebay.com look for people that is saling parts for these TV's.
May 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
I have a 35-inch Mitsubishi TV Model CK-35MX2. It is 15 years old but has never had a problem. Recently, when I first turn it on in the morning, the picture has a vertical roll until it warms up and after...
I have a Mitsubishi  "CS-3515R.  Serial number 528801. When I turn it on by remote or on the set itself, I can hear the power come on.  BUT there is no picture and no sound.  What do I do?
Oct 20, 2008 | Televison & Video
Mitsubishi CS-35805 TV
Sorry to be the one to inform you Sheri, but this set is known to have several bad capacitors in the sweep as well as the power supply. Unless you have an ESR type capacitor checker, your going to have to take it in for service, by a pro. Hope yopu did'nt pay to much for it. Good Luck
Jul 24, 2006 | Mitsubishi CS-35805 35" TV
Televison & Video Logo
483 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
