Question about Compex MicroHub 8 Networking Hub
What is the Input Voltage of MicroHub/8 TP1008C
2 Suggested Answers
SOURCE: Adapter specs
hi..
i've also got one without DC adapter... and looking around. find this link here: http://www.corg.ru/products/Network%20equipment/Compex/TP1008C saying: Power Supply: External power adaptor input 220V-110V, output 7.5v/1A
hope it helps
Posted on Oct 16, 2008
Need a replacement power supply for a Evernote scanner
Sorry Gregory, gave you the wrong number.
You could try something like this. Various voltages and currents with different adapter plugs. This is on Ebay UK but I would think there are others, don't know where you are.
Ebay item number: 201154296095
Specs:
1.Rated Input Voltage: AC 110V or AC240V
2.Vibration Input Voltage Range: AC95V-265V
3.Input Rated Current: 0.4-0.6AMP
4.Input Power: 90W
5.Efficiency: >88%(TYP)
6.Out Power: 90W
7.Output voltage: 15V/16V/18V/19V/20V/22V/24V(0/+0.5V NOLOAD): DC15V-24V
8.Output voltage: 15V/16V/18V/19V/20V/22V/24V(-0.4/0.5V@rating load): DC15V-24V
9.Output current: 15-20V/4.5A@22V-24V/4.0A: 4.5AMP(max)
10.Overload protection: YES
11.Short Circuit Protection: YES
Dec 17, 2014 | Office Equipment & Supplies
What is the output specification of the hub T1008c network hub
8 port 10 Base-T (10 Mbps) with a BNC for Coax cable connection.
Dec 04, 2012 | Compex Computers & Internet
Power adaptor got burned
Try another power adapter, it may have been damages by a power surge.
The power adapter may just have failed and caused no damage to the hub or the hub failed and caused the power adapter to fail as well.
Dec 04, 2012 | Compex MicroHub 8 Networking Hub
My landice 8 tradmill says safe and will not move
1) rUN THE SOFTWARE CALIBRATION for diagnose and troubleshootin.
2) Lube the deck belt
3) Lube the rollers bearing
4) Measure the input voltage motor, if there are the motor need repair
5) Measure the output voltage boad, for input voltage motor, if there are not the board is faulty. see the block diagram
God bless you.
Jun 18, 2012 | Landice Exercise & Fitness
Soft strider by healthrider tread mill does not function and the error code PO comes up any suggestions?
1) Please exchange batterires for a new ones.
2) Tight the flexible cables from keypane vs display board.
3)Tight the connector from display board vs lower board(Main motor board)
4)Adjust the reed sensor switch by 1/8" or 3mmsSee the diagram attached.
5)Measure input voltage for 115 Vac to input of main motor board
6) Measure input for power supply for +5VDC to main motor board.
7)Measure output voltage for +5vdc to Display board.
8) Finally see the block diagram that I am attached that I did for people like you. For easy diagnostic and troubleshooting.
Sincerely. Merry Christmas.
Ernesto CuaddraManagua, Nicaragua.12_24_2011_4_58_14_pm.gif12_24_2011_4_58_29_pm.gif
Dec 23, 2011 | HEALTHRIDER R60 SoftStrider Treadmill
04 zx6r code 15
some info from the manual (636) fault code 15. hope it helps??
Atmo- Absolute Atmospheric If the atmospheric pressure sensor system fails
15
spheric Pressure (the signal is out of the usable range, wiring short
Pressure Pa =100 mmHg - 900 or open), the ECU sets Pa at 760 mmHg (the
Sensor mmHg standard atmospheric pressure).
Atmospheric Pressure Sensor (Service Code 15)
Input Voltage Inspection
NOTE
o Be sure the battery is fully charged.
o The inspection is the same as "Input Voltage Inspection"
of the throttle sensor and the inlet air pressure sensor.
• Turn the ignition switch OFF.
• Remove the ECU (see this chapter). Do not disconnect
the ECU connectors.
• Connect a digital voltmeter [A] to the connector (8), with
the needle adapter set.
Special Tool· Needle Adapter Set: 57001-1457
Atmospheric Pressure Sensor Input Voltage
Connections to ECU
Meter (+) --+ BL lead (terminal 1)
Meter (-) --+ BRISK lead (terminal 14)
• Measure the input voltage with the engine stopped, and
with the connectors joined.
• Turn the ignition switch ON.
Input Voltage at ECU
Standard: 4.75 - 5.25 V DC
*If the reading of input voltage is less than the standard
range, check the ECU for its ground, and power supply
(see this chapter). If the ground and power supply are
good, replace the ECU.
*If the reading is within the standard range, remove the
seat cover, and check the input voltage again at the sensor
connector. *Remove the air cleaner housing (see Air Cleaner Housing
Removal).
• Disconnect the atmospheric pressure sensor connector
and connect the harness adapter [AJ between the main
harness connector and pressure sensor connector.
• Connect a digital meter to the harness adapter leads.
[8] Atmospheric Pressure Sensor
Special Tool - Throttle Sensor Harness Adapter #2:
57001-1408
Connections to Sensor
Meter (+) -l' BL lead [C]
Meter (-) -+ BRISK lead [OJ
with the connector joined.
Input Voltage at Sensor Connector
*If the reading is out of the standard range, check the
wiring (see wiring diagram in this section).
*11 the reading is good, the input voltage is normal. Check
the output voltage.
Output Voltage Inspection =
• Measure the output voltage at the ECU in the same way °0
as input voltage inspection. Note the following. 8 .~ (j')
Digital Meter (AI ®~O ECU Connector IS]
Atmospheric Pressure Sensor Output Voltage ' 11 .
Meter (+) ~ GfW lead (terminal 4)
Meter (-) -+ BRiSK lead (termina114) tC·lInn, C ,
Output Voltage
Usable Range: 3.80 - 4.20 V DC at the standard
atmospheric pressure (101.32 kPa, 76
cmHg abs.)
NOTE
o The output voltage changes according to the local at·
mosphen'c pressure.
D The atmospheric sensor output voltage is based on
a nearly perfect vacuum in the smaJl chamber of the
sensor. So, the sensor indicates absolute atmospheric
pressure.
*If the output voltage is within the usable range, check the
ECU for its ground, and power supply (see this chapter). If
the ground and power supply are good, replace the ECU.
*If the output voltage is far out of the usable range, remove
the fuel tank, and check the output voltage at the sensor
connector [A] (when the wiring is open, the output voltage
is about 1.8 V).
• Connect a digital meter [A] to the harness adapter leads.
[8) Atmospheric Pressure Sensor
Special Tool· Throttle Sensor Harness Adapter #2:
57001-1408
Meter (+) -+ GfW lead [C]
Meter (-) -+ BRlBK lead [OJ
Output Voltage at Sensor
cmHg abs)
*If the output voltage is normal, check the wiring for continuity
(see next diagram). *If the output voltage is out of the usable range, replace
the sensor.
Apr 17, 2009 | 2001 kawasaki ZX-6R Ninja
Adapter specs
hi..
hope it helps
Aug 07, 2008 | Compex MicroHub 8 Networking Hub
Lan
Hi - you connect the ethernet port on your modem to the wan port on your hub. You can then hook up your other devices to your hub. If this solves your problem PLEASE rate this as fixed. If it didnt, DO NOT RATE yet. Just add a comment letting me know you need more help and I'll be happy to assist you furter. Thanks and have a nice day. Remember if you need more help just add a comment.
May 10, 2008 | Compex MicroHub TP1008C Networking Hub
Connecting campus wide networking to hub
Check the following:
Hardware First: Is Vista confirming LAN connection onn that PC, or is it showing disconnected cable?
Is the connection properties showing at least 100Mbps?
Are the RJ45 terminals okay?
Is the driver for the network card recognized by Vista and loaded?
If that is fine, then check the following in the network properties:
1. The IP address you are using
2. The gateway address: it must be the same as the gateway address in the other PCs accessing internet. Run and check
3. The Subnet mask. Use 255.255.255.0
4. HAve you Setup the Nework using the Setup Wizard, including Access INTERNET THROUGH A HUB THROUGH ANOTHER COMPUTER ON MY NETWORK?
Check those things and let us know. Ask for help from your network administrator about correct IP addresses on that LAN
Feb 26, 2008 | Compex MicroHub TP1008C Networking Hub
Compex MicroHub 8 Networking Hub Logo
308 people viewed this question
Top Compex Computers & Internet Experts
Sandeep Kamat
Sandeep Kamat
Rose li
Rose li
Are you a Compex Computer and Internet Expert? Answer questions, earn points and help others
