Question about Vacuums
Royal RY7500 Manual - Vacuums
  • 312 Answers
Hi, I was unable to successfully find the manual for the RY7500 but I did find the Manual for the RY7600. Normally when a model number is changed in this way, it should be very similar in design. Hopefully that is the case here.
Hear is the link
Happy New Year,
Mark
http://www.retrevo.com/d/ds/progress?doc=390b6ce7cd6951e679666e3674bc4ffa&rk=0.26720473742031536
Posted on Jan 02, 2011
My bag style RY7500 Vacuum has a broken hose.. i can't find the part to replace anywhere online. Also don't know how to remove/replace.
You don't mention where it broke. Is it broken off at the very end or in the middle somewhere. If the ends are still OK and you love that vac, you can fall back on an old trick used by the military in WWII - duct tape! Find another vac hose the same diameter (any vacuum repair store will have them in stock) or you can take a piece of hose to a home improvement store to match up.
Cut out the broken area as evenly as possible. Cut a new piece of hose the same size you removed so the hose remains the same length. Wipe off the edges to remove any dirt. Lay your tubing on newspaper or cardboard. Next you'll need a sealant that will not only stick the parts together, it will remain strong after drying. (Silicone or epoxy glues both work.) Work on ONE break at a time. Apply a thin bead between the two pieces & press together. DO NOT DISTURB but leave the pieces to dry 24hrs. After it's dry use duct tape to reinforce the break (trust me, you'll be glad you did). Then fix the other side of the cut-out.
If it broke off at the very end, remove the hose from the connectors on both ends. Clean out any old hose -if any - if the hose fits inside the connectors. If it fits over a connector, make sure the outside's clean & smooth. Insert/Apply a new hose using the sealant. Duct tape after it's dry. (Yeah, I love the stuff. Saves a ton of extra work by supporting the stressed area.)
If it's just a small crack in the hose clean the broken ends so there's no dirt. Fill the crack in the hose with a thin bead of sealant, dry & duct tape it.
I've used this trick many times, so I know it works. Good Luck!
Feb 11, 2015 | Royal RY7500 Bagged Upright Vacuum
I need a manual for Royal 4600 cannister vacuum
I have a PDF from Royal for you.I would be happy to email it unless it is possible to post it here..?
Jun 08, 2014 | Royal Metal Canister Vacuum Cleaner Upper...
Problems with Royal 4000 Classic Bagged Upright Vacuum?
Try this site.
https://www.2instructions.com/search.php?cmarque=ROYAL&modele=4000%20CLASSIC
Aug 05, 2009 | Royal 4000 Classic Bagged Upright Vacuum
I need an owners manual for a Royal Precision 7910 carpet steam cleaner
http://hoover.com/file/160/ is the pdf for Royal Procision 7910 carpet cleaner.
Jun 06, 2009 | Vacuums
Vacuums Logo
53 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
