Question about Refrigerators
My fridge door is very loose inspite of changing the gaseskit the door remain open it dosent stick.
  • 944 Answers
Make sure no part of the seal is bunching up. Door hing may also create this problem seat it properly. Sometimesa refrigerator's door hinges go out of adjustment
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 02, 2011
Door of intergated fridge wont shut
This is a really open question but I assume you have checked for items inside causing obstruction.
That done now look at the hinges, it is possible one or either of them have become dislodged possibly from the bolts coming loose or from being shut with a something sticking out inside.
Another possibility is the magnetic strip around the door has come off, its an easy fix just push the little poppers back in the holes on the door.
More info would help answer the question.
Mar 10, 2015 | Refrigerators
Light will not go out when door is closes
It sounds like the door switch is sticking in the on position to me>
Does it go out if you manually press door switch with the door open?
If it doesnt then its almost certainly a sticking door switch. You may have to bring this unit completely out of the fridge to look at it and then test it for a permnanently closed contact.
Mar 05, 2013 | AEG 10.35 cu. ft. / 293 liter Upright...
Fridge is out of gas in fridge compartment. Freezer compartment is in order
if the freezer is operating ok,then the refrige side isnt out of gas,its the damper vent door between the freezer and refrige thats not opening to let cold air into fridge from freezer,sometimes they stick shut due to ice from condensation on this door,remove grille cover on damper door and check this,if iced up defrost it with a hair dryer,then change temp selector and make sure door then moves with temp change
Mar 24, 2011 | Refrigerators
Princess series model FN66011S The refrigerator does not change temp.it remains warm...freezer does freeze. Is this a fixable problem?
HI!!
The little fan inside the freezer is the one in charge of blowing cold air into the fridge area, the freezer control (thermostat), regulates how cold it should get, and the Refrigerator control regulates how much of this cold air goes to the fridge compartment. It is important to keep the door gasket clean at all times in order to have a good thight seal.
Check:
1.- That the freezer and fridge controls are set correctly, acording to manufacturers specs. (a common problem arises when by accident, the temp. controls are moved out of preset adjusment.
2.- That the fan is working and sounds strong, (If you keep the freezer door open for a couple of minutes, you should hear and see the motor kiking in.)
3.- Find the vent(s) in the fridge compartment and feel if cold air is coming thru when fan is working. If fan is working and blows no air, Take the freezer's back panel off, (4 hexhead screws) just enough to see inside and check if the evaporator (radiator looking component) is covered with ice, blocking the flow of air towards the fridge compartment, if it is, your defrost thermostat and-or timer are defective.
Your temp control for the fridge when you first start it, should be a bit higher than the one for the freezer. (the freezer should be in the low-middle range.) This control is nothing but a actuator for a door that controls the flow of air from the freezer. The bigger the number, the wider the door opens, and the colder the fridge gets.
Once the system is stable, let's say the next day, you can re-adjust your controls, (don't expect an inmediate change right away, change one digit a the time and check again next day) If you set your fridge too high and the freezer too low, the freezer may loose coldness and the problem would invert.
Good Luck!!!
Mar 20, 2010 | Refrigerators
Fridge door does not close on it's own. possibly missing spring.
There are no springs to assist refrigerator doors to close.
The fridge doors can be made to close themselves by adjusting the height of the feet of the fridge. "Pitching" the fridge slightly away from the hinge will accomplish this. If the foot on the hinge side of the fridge door is slightly higher than the foot on the handle side of the door, the door will usually want to close by itself. If the fridge is a side-by-side type and this is done, one door will close by itself and the other will want to remain open (or open fully). In this case, it's best to have the fridge as close to level as possible.
I hope this was helpful.
Nov 28, 2009 | Amana Refrigerators
The lights do not turn on when opening the doors despite changing the bulbs.
It sounds like the door switch. Check to see if it is sticking -- it should come out when the door is open. If it's not sticking, the switch probably needs replacing.
May 02, 2009 | Refrigerators
My fridge stopped cooling but freezer is still working. Warm inside
sound like the freezer evaprator may have frozen up or that you hacve a damper sticking on your unit. post your model number and make and then it will be easier to point you to the problem.
Jan 09, 2009 | Refrigerators
Freezer door opens
its air pressure between the wo doors that cause it to open the freezer door.take some soapy water and clean the sels aroundboth doors to see itf thet dosent help use dish soap and a little water to clean the seals with it should stop it
Jan 07, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Apr 01, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
