I have a new Singer Simple Sewing machine, when sewing the thread either comes loose & doesn't sew or it gets tangled up under the material. I have already rethread over and over, still have problem. When it does this it feels as if the needle is hitting something or its pulling something. I have opened up where the bobbin is and slowly turned the handle with material there, after turning a few times I notice the thread building up in the bobbin area like it?s getting stuck on something.
try changing the needle---flat side goes to the back side of the machine also check the top tension depending on the fabric your sewing on--the needle & thread have to work with the fabric--example light fabric needs a different needle & thread than a heavy fabric check to see if the thread is coming off the thread take up lever when you sew.
try a new needle rethread the machine--top & bobbin clean under the needle plate area & in bobbin area for lint & loose threads check to see if thread comes off thread take up lever
have you tried a new needle?
the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Or the needle could be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
4.also clean under the needle plate for lint & loose threads
check to see if the thread has come off the thread take up lever
It is the top threading that is giving you the problem not the bobbin thread. Try this, totally rethread, the machine. A new needle will not hurt either. Now with the presser foot up, pull on the top thread, it should feed smoothly, now lower the presser foot, pull the thread again, it should barely move. This usually will seat the thread in the tension discs. Good luck and Merry Christmas
It is usually in your top threading, make sure that your thread match in bobbin and top threads. Mixing sometimes causes a problem. Also make sure that nothing is tangled. Also, check your needle and put a new one in just to be sure, then check your manual for size of needle and what kind of project you are doing. Hope this helps.
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
Sounds like you threaded it wrong and kept trying to sew, gently get all of your material out of the machine, DO NOT FORCE, GENTLY ROCK IT OUT OR YOU WILL WRECK THE MACHINE, also watch your dvd and learn about threading from your book. Always, hold your thread ends when you start to sew. If, you cannot find your manual go to www.singerco.com, I have sewn for 50+ years and found that the dvd was very helpful, each machine is different.
Check your tension disks, with your presser foot up, and the tension dial on zero. Sometimes a piece of cotton breaks off between the tension disks and then prevents the disks to work properly. Also make sure when you thread the machine, the thread does go through the disks and over the take up lever. After you threaded the machine, before putting the thread through the eye of the needle, lower the presser foot and while pulling on the thread with your left hand, increase the tension with your right hand. Do it slowly and you should feel in difference in tension. If this is the case, your machine should work fine. Also use a ball-point needle on t shirt material. Good luck!
