Question about Whirlpool ED2FHEXN Side by Side Refrigerator
My whirlpool side by side mode ED5FHEXNS00 (bought 2004) freezer stops cooling to 0 degree F. It only cools to the same temp as the refrigerator compartment. It does not cycle off and is working all the time today. I can also hear a ticking sound every few minutes. Not sure where the sound comes from. Any ideas of what went wrong? All the frozen foods are thawing now. please help!
  • 4,070 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Part 6 on this diagram is your defrost control. If it is where the clicking is coming from it's probably bad. It controls the defrost cycle
Posted on Jan 02, 2011
Freezer temp not steady
it is cycling different because the environment is much colder..
Jan 21, 2014 | Whirlpool Refrigerators
Freezer defrosting
You may have to reset the defrost timer.
Nov 23, 2017 | Whirlpool Refrigerators
I have a Whirlpool Gold side by side bottom Freezer gi7fvcxwqoo. The refrigerator side is not Cooling very will. The freezer seems to be ok! Does anyone know what's wrong?
Either the refrigerator is too cold to run properly in the location of your patio, defrost failure. or air damper is not opening and closing properly. First I would like you to enter the control panel into diagnostic mode=> GI7FVCXWA GI7FVCXWB GI7FVCXWQ Diagnostic Test I am going to be here to assist you in locating the problem but because your model has so many electronic features I am asking you to do the diagnostic test first to help pinpoint any problem your refrigerator may have that can be located while in diagnostics. You may get the complete repair manual by contacting me HERE
The temperature of the freezer should be colder and around 0 degrees F. What is happening here appears to be a defrost problem. 12729123 Defrost Heater
another source here=> 12729123 Defrost Heater
I am here so please let me know if you have questions Thanks Sea Breeze
Apr 22, 2013 | Whirlpool Refrigerators
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer get up about 27 degrees and then start going back down to 0 degrees. Does it everyday.
Sounds like the defrost timer/control is sticking...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
We just bought the house so we are not used to this. Could it be in defrost mode. The freezer is ok but as said the temp goes up a degree and now at 20c
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 02, 2010 | Frigidaire FRS-26DR7D Side by Side...
I have a GE side by side Fridg.that is approx 7-8yrs old.The freezer side is working fine but the fridg. side is not cooling. staying at about 50 degrees just barely cool.. This seemed to happened...
Setting the cooling setting up all the way will not help at all.Make sure your freezer and refrigerator controls are about the same setting. Temp. settings for refrigerator should be between 38-42.degree at medium.. Freezer about 0 to -10.If it is a simple fix this will help.
Feb 20, 2010 | GE GSS20IEP Side by Side Refrigerator
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Freezer/Fridge not cold enough
check see if compressor on check control if on
Apr 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Bought used side-by-side. How long should it take to cool down?
It should have cooled down in just a number of hours. Call the people who sold you this and give it back if you can. It sounds like a lemon somebody wanted to get rid of.
Jun 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
381 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
