Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
I need the plastic part in the freezer that keeps the ice from coming out when you open the door?
  • 472 Answers
Not sure where your located but try this site they sale to the public and i believe will ship to you... i do business with them on a daily basis in the texas area and they are all over the united states... apdepot.com you should be able to input your model number and make of unit and get a parts diagram so you can order the correct part yourself... good luck
Posted on Jan 02, 2011
5 Suggested Answers
  • 7 Answers
SOURCE: whirlpool refrigerator side by side Ice control
its a defrost sensor that reads the inside temp of your freezer so it knows when to defrost itself.you need to close it so it wont allow th freezer to freez up.
Posted on Oct 12, 2007
SOURCE: How to replace Ice Door Solenoid
I got help from repairclinic.com , and didn't see any reference to a solenoid. I fixed my GE fridge, its model is #TFX27FJB,,,,Free!!!! The replacement part would have cost 46.60.
On inside of freezer door, behind ice dispenser, there is a panel about 7x9
(plastic) that you can gently pull the tabs free and remove the panel. You will see the mechanical stuff. There are 2 gear like (pulleys) that are in the center area,supposed to be connected by a part that is about 3-5 inches long , like a small wire cable with hook type ends, think it's called "lanyard cable" , mine was broken, so I patched it with some scrap wire,,,one end hooked to one pulley and the other to other pulley(gear). When my ice door quit closing after getting ice,this cable had broken, What I did was find a small wire, to fix the break,, using as much of the original cable as possible, make sure that total length is same as original. Hook one end to one pulley and wrap it around it, it has to be wrapped a certain way, I can't remember counter-clock wise or vise-verso, till it will take up all slack, and just reach and hook to the other. I think it is a spring that opens door, and then the gears turn to close it, that is why it has to be wrapped with no slack.
It cost nothing and it works great now,, the repairclinic.com will show you specs so you can see what you are doing.
I didn't want my food to thaw, so I had a large piece of Styrofoam that I cut to fit in door jam, to keep food safe.
Good Luck
Hope this helps.
Barbara H.
Posted on Mar 20, 2009
  • 152 Answers
SOURCE: plastic ice dispenser cover in freezer door
The door part # is 61005883 and the strick which holds the door is part # 61005886
Posted on Feb 17, 2010
heatman101
  • 43501 Answers
SOURCE: Bosch frost free fridge freezer iced up and door won't stay shut
Check out these tips...they can help you figure out whats going wrong...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 12, 2010
Freezer noise when door closed
Most likely a noise from the freezer fan motor. Possibly the plastic blades are cracked or a piece broke off causing an off balance condition. They could also be rubbing some excess ice back there.
Jun 28, 2015 | Amana Refrigerators
ICE BUILD UP ON INSIDE BACK OF FREEZER.
The air in the freezer is circulated by a fan, there are a number of possibilities
1. Is the internal fan running, this may be switched by the door opening, to test push the small switch on the door frame ( if fitted). If the fan is running go to
2. If the fan is running can you feel air coming out of the bottom of the duct inside at the bottom.
3. If there is no air coming out of the duct the duct is possibly blocked with ice, or the cooling coil at the top is iced up.
4. If there is no air flow then the best and quickest option is to empty the freezer, store your goods elsewhere, switch it off, use a wedge to keep the door partly open and leave off for at least 24 hours. You may find a large pool of water on the floor after this and you will also need to dry out the inside of the cabinet.
Icing of this type is caused by
1. Door not being closed properly, door misaligned or faulty door seals.
2. Putting "hot" product (over 2deg C / 34 deg f) into the freezer.
3. Not covering or sealing product being stored in the freezer.
4. Defrost timing not working (ask your service guy) for this and the rest I'm afraid
5. Defrost heater not working
6. Blocked condensate drain
7. Faulty thermostat, keeps on cooling
Hope this helps
Apr 14, 2011 | Arctic Air 22 cu. ft. Commercial Freezer...
Ice maker will not make ice cubes, only crushed ice.
take out your ice bin the look in the back of the freezer and ytou will see a small hole with a plastic sqaure actuator.hold the door switch closed and make sure the unit is selected for cubed ice then try and dispence ice if the swaure plastic acuator moves up it is working fine it shoeld drop down when you release the dispencer arm.if it dropps back down then make sure that the metal bail arm is properly inserted into the hole in the auger case when that actuator moves up this opens the small plastic door on the ice bin to allow subed ice to come out.make sure there is no ice build up on the ice bin that would stop the trap door from opening.good luck with you fridge i hope this helps you out,let me know how thing s go for you.
Jan 20, 2010 | Frigidaire FRS23H7C Side by Side...
Samsung side by side refridgerator rs2630sh freezer not working other side is
Open freezer door, pull evrything out so that you can see back inner wall, look at plastic housing and see if you have ice/frost building from bottom to top of plastic cover, if so you have lost the ability to circulate air, drain possibly plugged up or evap fan not working or possible other cause. If you see ice/frost buildup shut refrig down for four days and let thaw (be sure to put towels aroundthe front of door area of freezer, the power back up and see if after starting if the fan comes on with the freezer door open and you holding in on door light switch(s). If fan does not come on within a few minutes of holding door switch(s) then evap fan is defective, call a repair tech or call samsung.
Oct 17, 2009 | Samsung Refrigerators
Water dispenser suddenly not dispensing water
Remove the bottom kick plate . Follow the plastic line about 6" and you'll find a connector . Push in on one end of the connector and at the same time , pull the line out . Close the door and press for water . If no water comes out of the disconnented line , the water valve is probably bad . If water does come out , the line inside the freezer door is frozen . If this turns out to be so , you can lower the freezer temp for maybe days , or , put the food on the door, inside the freezer , tape the light switch down ( to keep the lite off and fan running ) and tape plastic over the freezer door opening so the freezer will continue to work . Reinstall the line back into the connector by pushing the hose firmly into place . Leave the freezer door open for maybe 1 or 2 days for thawing out , going by ocassionally and pressing the water dispensor . Important : lower the freezer temperature slightly to keep line from freezing again . ONLY CHANGE THE FILTER WHEN WATER FLOW SLOWS OR ICE CUBES GET SMALL . The change filter lite comes on by the amount of times water dispensor is used and to make money for the vendor .
Aug 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Whirlpool refrigerator side by side Ice control
Oct 12, 2007 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side by Side Refrigerator Always dispenses crushed ice regardless of setting
I know it will be a pain but take it apart again and lube the metal shaft in the solenoid and the plastic slide with petrolium jelly, that should keep it from freezing up. It's what we do...
Dec 25, 2006 | GE GSH25JSRSS Stainless Steel Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
