Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Macbook pro network connection
I have a macbook pro and i cannot connect to our home wireless internet. our other dell laptop has no problems connecting to the internet though. When I try to join our network it says there was an error joining the airport network.. then the name of our network. i have connecting with this computer to this network before and no it won't connect to it at all.. ?????
  • 1 more comment
  • orionrush Jul 13, 2008
    I have the same problem - the one clue is that if I power cycle the modem, the problem goes away for a few hours, however the problem persists with a restart of the laptop. I've noticed the problem crop up when the wireless signal diminishes. When it returns I can't join the network. Same thing happens if my laptop falls asleep for a few minutes and I try to log back in.
    Seems to me that either the laptop or the modem looses the plan along the way. There is something about the handshake after the connection has established and lost - that the modem isn't ok with.
  • wad36m Aug 23, 2008
    I have the same problem. Other laptops in the house (not macs) all can connect but my new macbook pro does not connect. Please help!!
  • amathestar Sep 13, 2008
    I also have the same problem. My ipod touch, wii, and macbook all connect fine. But for some reason my macbook pro wont. It says "connection time-out" when I put in my password. Help!
Verizon, the ones who sent me the router, helped me fix the problem. The router/modem software has to be updated because the old software can't work with the new version of leopard. The technical support guy did all of the updating via a screen share, so your best bet is to call the company who sent you the router and get their help.
Posted on Sep 13, 2008
My wireless adapter cannot see any wireless networks in range
you have a problem with the range or apear one indicator network work of ? if is the first maybe the ip adrees is corrupt in you mac conections or if not apear any your airport mac adaptor is work out change it vote plase
Mar 05, 2012 | Dell XPS M1210 Notebook
Hi there, I got an Apple MacBook Pro, OS 10.6.7 and recently got problems connecting to my wireless internet at home. I've got no problems at all connecting to other wlans (at work, at friends'...
So you're knowledgeable, good. Do you have the SSID broadcasting or not? Do you have WEP or WPA, etc active? Can you find the network you are trying to connect to under preferences on your MacBook Pro? Does your network show up? Either way, delete it and start over. If you re-set up your network and it still doesn't find it, but the other machines in your house work wirelessly, it is still a configuration issue. Do you have your wireless network as the default network to find? Do you have a help desk that you can call at your workplace? Give me more details and i'll continue to try and assist.
Jun 10, 2011 | Computers & Internet
Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Apr 02, 2009 | Dell Vostro 2510 Laptop
Limited or no connectivity on a laptop
you check your router configuration
your wireless configuration
number o hosts limited
Feb 25, 2009 | D-Link AirPlus DI-524 Wireless Router
No Internet Connection
Hi kathy
I believe you are connecting to the internet using wireless. Are you using this laptop to connect to a home wireless network or you connect using a cable. This will be a good way to analyze your problem
Post the ip address that you are getting.
You can get the ip by
start -run-type cmd enter
you will be in the black command prompt
just type ipconfig
and let me know what you get under ip address.
Also let me know the wireless router, your Internet Service Provider and also how many systems are there are at your home if you are connecting to a home wireless network.
Also let me know which is firewall or antivirus program that you have.
thank you do let me know if this works and do share your experience.
thank you
rakesh
Expert in Dell
Jan 05, 2009 | Dell Inspiron 6400 Notebook
My new macbook white does not configure.
Can you connect hardwired?
If so, try selecting "Software Update" from under the Apple in the upper Left hand corner. There have been a number of updates that effect wireless connectivity.
Additionally try repairing permissions Application / Utilities / Disk Utility
Dec 16, 2008 | Apple MacBook Pro Laptop Computer with...
Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Dec 05, 2008 | Dell Inspiron 6000 Notebook
How do i use my built in wireless connection to connect to the internet,please.
make sure that your wireless or wifi light is on,you may try to press Fn and F2 at the same time to enable or swith on wireless..if wifi is already on,try going to start >> control panel >> network connections,go to wireless network connection and double click it, it will give you a list of wireless network,or right click and then "view available wireless network", if you get an error that windows cannot configure wireless connection,go to start >> all programs >> loo for either dell wlan utility or intel pro wireless, by opening that app,it will also search for wireless network in range,just double click on the network name where you want to connect and you sould be connected provided that "wireless network" doesnt have encryption like wpa or wep key..if your connecting to your home network,you should have wireless router at home and wireless is enabled on the router.
Oct 05, 2008 | Dell Inspiron E1705 Notebook
MacBook Internet connection
ok call me or I can post for you. I know what your problem is. But i need to know what model netopia router you have. Kepp in touch
Thank you
Jason
Feb 09, 2008 | Apple MacBook Pro Laptop Computer with...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
576 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
