Question about Refrigerators
How do I get the light bulb out - does it unscrew or just pull straight out
  • 944 Answers
It depends on the model.In some model you have to unscrew it.In most model you have to unscrew it only.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 02, 2011
How to Change the rear left blinker light.
you will usually have 2-3 screws on light cover. Lift the hatch and look on inside. Take those out and you then will see 3 sockets with bulbs in them one is rev light, one is brake and other is running light. Depending on which one is out unscrew counter clockwise and pull out. Bulb pulls straight out
Jan 19, 2011 | 2005 Dodge Grand Caravan
I want to replace the bulb for the third brake light, but the bulb is impossible to unscrew. Is there some technique which is not described in the owner's manual?
I can't remeber what bulbs they are,, but if they are 194 peanut sized bulbs they just pull straight out they may have melted some of the plastic or rubber and are tough to come out same with any of those 3rd brake light bulbs that are bigger ..if its 1157 or 1156 they do turn out 1/4 turn ,, 3057 bulbs also pull straight out but you may have to use force not finesse to remove them they may break but you can dig the rest of them out of the socket after..
good luck
Sep 27, 2009 | 2004 Buick Century
Amana AMV5206AAQ light on the bottom of the microwave out
This is the replacement: Lamp, halogen
It pulls straight out of the lamp socket and the new can be pushed in.
Go here for more
RepairClinic.com
appliance parts, help & more
May 08, 2009 | Amana AMV5206 Microwave Oven
Steps to replacing right front signal light bulb in 2005 Malibu
Raise hood and remove two hex bolts holding light assembly. You will see three round rubber covers, approximately 4" in diameter. Unscrew the one to the far left, giving access to the signal light bulb. The bulb pulls straight out. Insert new bulb, replace rubber cover, attacht light assembly back to vehicle with hex bolts, close hood, and pat yourself on the back for job well done.
Mar 30, 2009 | 2005 Chevrolet Malibu
1999 isuzu rodeo ls
On the left hand side of the truck, there are two screws that hold the light assembly in place. Unscrew them and slowly pull the light assembly straight back. Then you can access the light bulbs from there.
Feb 21, 2009 | 1999 Isuzu Rodeo
Replacing license light bulbs on 2002 Chevy Trailblazer - How to?
Just pull bulbs straight out be careful not to beak bulb
Feb 18, 2009 | 2002 Chevrolet TrailBlazer
Break kight burned out
Open the liftgat and you should see the screws on the side of the lamp. Unscrew then and pull the lamp away from the vehicle. There should be sockets in the tailamp that screw in and out about the size on a half dollar. Pull this out and pull the bulb out straight and replace by pushing in a new bulb. Follow these directions backwards to replace the lamp. Hope this helps.
Jan 12, 2009 | 2006 Jeep Commander
Replace rear turn signal bulb on 2007 H3 - driver side
1st::Unscrew the 2 screws that hold the light in.
2nd::Slide your hand behind the light and pull the light towards you. Make sure that you pull it straight, as if the h3 was driving away from you, so you dont break the two pins that are holding the light in...PULL ONE PIN AT A TIME!!!
Dont pull it to far away from the hummer as there are wires attached that need to stay attached.
3rd::turn the back of the bulb to unlock it from the lens...
4th:: slide the bulb out and remove thebulb by pulling it straight out.
5th::put the new bulb in, lock it back into the lens, then insert it back where you got it from,...
MAKE SURE you move the wires out of the way when you put the lens back in...they will get in the way and can be damaged.
Jan 10, 2009 | 2006 Hummer H3
2007 Dodge Nitro Tail Light Replacement
look at the car manual under maintenance and then rear light bulb replacement. First take out the two hole covers using a flat head to loosen then wiggle and turn by hand to get out. Pull the light unit straight back, and unplug the electrical. Don't break anything.
Then use a star driver (check your misc socket set drivers for the right size). Unscrew the two star head screws and pull this bulb holder straight off the tail light (same direction as screws). Replace the bulb and put back together in reverse.
Nov 04, 2008 | 2007 Dodge Nitro R/T New Cars
Replacing a brake light bulb for a 2006 chevrolet equionx
I just replaced the p/s brake light:
1. Pop off the tabs that cover the screws. (flat screwdriver)
2. Unscrew both screws. (philips-head)
3. There is a metal post attached to the light assembly located towards the front of the assembly pointing in towards the center of the car. This post fits into a rubber grommet that is attached to the car. I had to wiggle and rock the assembly to get the post free from the grommet and the assembly off the car, by pulling to the right.
4. Re-assembly requires lining up and inserting the post back into the grommet (use your best Beavis and ******** sound effect now). Put the screws back in and don't forget the covers.
Jun 20, 2008 | 2006 Chevrolet Equinox
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
