Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
My out board is a30hp yamaha 3cyl starting to oil plugs and and under load not running well have had it serviced and was told all was well i replaced spark plug s and ran well for to outings but 3 rd time out did the same as before
  • chris wheeler
    chris wheeler Jan 02, 2011
    can you please be more specific -- I am not sure what " starting to oil plugs " mean.
    but I work out at a fishing lodge in Alaska and we run the same motors on all our boats AND in the back of my head I am sure I know what your problem is, I just want to make sure I give you the right information.
    c...
  • 293 Answers
In order to know if its bad fuel, too much oil or low compression you need to perform a compression check. You should have no more than 20% difference across all three. Compression should be above 100psi. This will show you where the problem is.
Hope this helps,Matt
Posted on Jan 02, 2011
Yamaha yp 400 2005 majesty will not go faster than 50 mph and revs no higher than 4500 rpm what is the problem?
Fuel starvation? Twisted or kinked fuel line? Some may be getting through to run the engine but not enough under load. Throttle adjusted properly? Only enough movement for low rev range.
Oct 11, 2015 | Yamaha Motorcycles
2001 yamaha yz80 backfires and wont start
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Bike won start just backfires occasionally
01 FZ wont start after back fire FZ1OA Message Board
Yamaha YZ125N1 Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 12, 2014 | 2003 Yamaha YZ 125
Bike spits and sputters at top end
Hi, Johnny and the usual suspects are:
1. Inlet system air leak.
2. Enrichener valve not seated or leaking.
3. Damaged or restricted fuel tank vent system.
4. Restricted fuel supply tract.
5. Dirty or damaged air cleaner element.
6. Plugged bowl vent or overflow.
7. Worn or damaged needle or needle jet.
8. Vacuum piston assembly malfunction.
9. Loose or plugged main jets or passages.
10. Improper float level.
11. Accelerator pumps inoperative.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Testing the Power Valve Yamaha 2 Stroke
05 yz125 sputter at high rpm Yamaha 2 Stroke
YAMAHA YZ250 LC Owner Service Manual
Dec 17, 2012 | 2003 Yamaha YZ 250
1985 yamaha maxim x wont start back fires and dies will run on starting fluid tho
Hi, Broken419 and the usual suspects are:
XJ700 no spark Backfire
Motorcycle Message Board Motorcycle USA
Yamaha XJ700N Service Manual
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Sep 08, 2012 | 1985 Yamaha XJ 700 X Maxim
2009 Yamaha yZ250 4th gear keeps getting hot and galling
Hi, Msportum5618 and I have been told, read, ridden, and believe the Yamaha YZ250 is an ICON and one of the greatest dirt bikes ever made. Any bike is subject to failure, especially competitive performance machines. The oil type is not the issue the usual suspects are:
1. Incorrect transmission oil level.
2. The oil delivery system to the shaft is malfunctioning.
3. The shaft is bent, runout should be 0.002" max bearing/running surface damaged/galled or has lost its hardness due to excessive heat/blue color and gear failure, a new replacement recommended.
For this scenario, you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2008 YZ250 not shifting
2009 YZ 250 lost 4th gear
YAMAHA YZ250F Owner Service Manual
Jun 06, 2017 | 2009 Yamaha yZ250
2003 yz450f leaking crankcase oil from bottom gasket shifter side, just had the top and bottom end redone. Ran it through break in dressed it with new rims, graphics, tires, chain, and sprockets. Seems to...
Hi, Robbinsjman1 you may have a leaky shifter shaft seal for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Shifter seal leaking YZ 400 426 450
Replace Shift Shaft Oil Seal in Seconds 2 Stroke 1998 YZ125 Example
YAMAHA YZ450F Owner Service Manual
http://www.yamaha-motor.com/assets/service/manuals/2004/lit-11626-17-11_784.pdf
Jul 11, 2011 | 2003 Yamaha YZ 450 F
06 Yamaha Roadstar misses under load
Carbs are not synchronize. Running richon yhe back and lean on the front. If each carb has irs own filer, check the rear carb air filter.. But for sure get the carbs synchronized. Good Luck.
Oct 05, 2009 | 2006 Yamaha Road Star
I have a 97 geo metro 3cyl 1.0 lt. Runs
Have you checked (or replaced) the O2 sensor. This can cause the engine to run bad at cold temps if the sensor is bad
Sep 22, 2009 | 1995 Geo Metro
Yamaha 30 HP 3 cylinder 2 stroke
pull the spark plugs and see if they look like there burnning the same if so then i dought its a spark issue and if it was in the lower unit u wouldnt here a loud anything it sounds like a rod bearing i have had the same thing happen to several yamahas under a load
Jul 06, 2009 | Light Outboard Motor Boat Bass Fishing...
2004 Yamaha WR 450 F oil leak from the cylinder head right above the exhaust port
Hi, Jkkesling219 for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
WR450F Bad Oil Leak
leaking oil from right side if cylinder weep hole wtf
Yamaha YZ450F Owner Manual
Mar 14, 2009 | 2004 Yamaha WR 450 F
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
96 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
