Question about Mitsubishi CS-40503 TV
Actually the model is cs-313050. its quite old. the problem is that the tv won't work in the way that when you turn it on (it won't even turn on anymore) there is nothing but a white or blue lineright in the middle of the screen. even when the cable is turned on you can't see the picture because its in the line. we've tried resetting it unplugging it and nothing will work. can you tell us what to do?
  • Mitsubishi Master
  • 2,098 Answers
You didn't mentioned if it is a horizontal line but i think it is.
It seems that you have a faulty vertical I.C. that scan vertical line.Because you it is defective you've lost the vertical scanning thats why you have only a horizontal line on the screen.
You will confirm it by powering on the unit with your cable signal present.When the sound is present on every channel it is confirm that you have a problem on the vertical section. You must look for a qualified technician to solve the problem....
Posted on Jan 02, 2011
My tv won't turn on
replace the power supply board @www.shopjimmy .com
Mar 09, 2013 | Televison & Video
Mitsubishi CS-35503 Blank Screen for a few moments then total loss of power, will not turn on
it must be some transistor that is failing.. i recomend you to give it to someone who can fix it for you, because tvs, even if they are unplugged, they can give you a strong electrical charge tat can even kill you..
Dec 20, 2007 | Mitsubishi CS-35503 TV
Mitsubishi tv 32 inch model number cs40505 won't turn on
Check its power regulator board. Check fuse. replace it as card basis, if found irrepairable.
Jun 14, 2012 | Mitsubishi CS-40505 TV
Where is a manual for a mitsubishi CS-31205 tv?
The manual for Mitsubishi TV model CS-31205 can be found by clicking the link below (Although the link says "CS 31305" , other models such as CS-31205, CS- 31309, and CS-31304, will use this guide as well)
Download Mitsubishi CS 31305 Owner Manual
Available for download (and offline viewing) in PDF format with a very short registration, or bookmark in your browser, and utilize online.
Or click below to visit the very useful website (the library is large, yet easy to use).
ManualsLib Makes it easy to find manuals online
(*just read this 2 year old question today- hope the OP found resolution)
May 25, 2012 | Mitsubishi CS-31205 TV
Green light on mittsubishi tv 65inch won't quit
It is the set's brain trying to boot up. (not unlike a computer) These sets if unplugged and power applied should blink 70 seconds and then go out and then can be turned on.
The model number will determine my answer/suggestions=
Models beginning with WD are nasty if this problem.
Models beginning with WS are not quite so nasty to deal with.
A full model number will tell which you have.
Mar 22, 2012 | Mitsubishi Televison & Video
MY MITSUBISHI CS-40503 WILL NOT POWER UP OR TURN ON LIVE IN FLORIDA ALOT OF POWER SURGES I DO HAVE IT PLUGGED INTO POWER SURGE PROTECTER?. CAN YOU HELP JOE
Same thing happened to me this week.Solved it today.Apparently this is a common problem with this TV.The cause and solution is actually quite simple.Capacitor C982 47uF/50V leaks and corrodes the 13 Volt Zenier Diode D982.Replace both and your TV will start like new again.Both are on the back of the main circuit board.Takes about 1 hour to fix it.Service call to a TV repair man should be about $100 total or you can do it yourself.Michael Marks(931) 561-1668 Glad to help.
Sep 18, 2011 | Mitsubishi CS-40503 TV
I have a Toshiba 26AV502R tv, was working yesterday and now it won't turn on? It's about a year old. What do I do to fix this?
the only thing you can try to do: unplug TV, let it "reset" for a minute or so, then plug it back in. If that won't help, means: surrender to repair service. for 1 year, even with 24/7 usage, there is a slim chance for "bloated" capacitors inside of TV's power supply, but quite a good chance of your main board failure. Now a days they quite compact, packed with high temperature producing IC chips, led-free solder, which has drawback of "fatigue" failure. Or, there might be power surge involved. In any case, except "lock up", appeal to TV repair service.
good luck,
Alex's Television,
215-806-5980.
Jul 16, 2011 | Toshiba 26AV502R 26 in. LCD HDTV
Our Mitsubishi purchased 9/1996. 40 in. CRT has been thru one move and still works perfectly.model CS-40505. What is average life expectancy? Thanks!
Hello
The average life expetancey will be related to the working hours of the TV. Normally CRTs are expected to work perfectly for 10,000 [Ten thousand] continuous hours. Even though they may actually work more than this time period, the focus and screen clarity will degrade with time. OK.
Jun 25, 2011 | Mitsubishi Televison & Video
I have a Mitsubishi cs-35505 tv. This model is an oldie, from '96, but still works... kind of. The remote is not really functional, even with new batteries and the internal speakers got turned off. I...
If you feel the remote is bad, you will need to find a new remote. The best option here is to find the MCM Electronics website. They will have a brand replacement. Thanks for asking and show a few hands of support!
Mar 21, 2011 | Mitsubishi CS-35405 TV
Fluctuating volume
It is near impossible to assist without the make and model. Please update this with that info and we should be able to help.
Thanks,
Dan
May 19, 2008 | Televison & Video
Televison & Video Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
