Question about Whirlpool Washing Machines
Hi my whirlpool show f and h and does not move to rains
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1.Make sure that both valves at the water source(s) are turned on all the way.
    2.Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3.Verify inlet valve operation
  • If there is water in the unit:
    1.Verify Drain pump operation
    2.Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Posted on Jan 02, 2011
Wind sensor doesn't work
Test all wires for continuity. 90.8 % of problems are caused by faulty wiring.
Aug 13, 2017 | dr. Tech WA-1080PC-T Solar Wireless Home...
Nelson RainTrain doesn't move forward
Hi, loosen both arms and roll them in the other direction and re tighten, basically the water is rotating them in the wrong direction, regards Phil.
Jun 07, 2012 | Nelson LR Rain Train Traveling Sprinkler...
How to wire hunter rain clik rain sensor to r8816p101c
1) There are different rain clik model numbers shown in manual
Open 24 volt Rain clik manual:
http://www.hunterindustries.com/resources/pdfs/instructions/domestic/lit358w.pdf
http://waterheatertimer.org/pdf/Hunter-rain-clik-instruction-manual.pdf
2) The rain sensor has two wires.
And two additional wires are needed to run from rain sensor to sprinkler timer. For example, buy thermostat wire from local hardware store if wire is not supplied.
3) The rain sensor has a terminal block where wires are connected. .
Open manual above to identify markings on your terminal block.
For example Figure 1 shows SRC model, and with this model number, the rain sensor wires connect to terminals RS and C, and then two wires going to timer connect to terminals RS and and 1.
4) R8816P101C is 208-240Volt 24-hour irrigation timer.
Timer has two separate terminals for attaching rain sensor.
5) Timer power connections have 4 terminals. Do not connect rain sensor to power terminals.
Connect wires from sensor to the two sensor terminals.
6) Timer slide-switch must be set to ON position for rain sensor operation.
Sensor sends continuous 24Volts to irrigation timer.
When it rains, the rain sensor stops sending 24Volts to timer. Timer responds by not turning on power to irrigation pump.
To by-pass rain sensor, move timer slide-switch to off position.
7) Open following link for Intermatic replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | Intermatic R8816P101C -...
Hi i have a whirlpool ac in my window its been raining alot and water has gotten in it. it turns on but dont blow air at all
With your statement, I understood a/c got ice formation in cooling coil.It's because of dirty filter & dirty coils. Service the unit. And due to less rpm or no running of fan also it happens. Rotate your fan manually, if it's hard replace bearings. If easily rotate, replace capacitor. Thanks.
Dec 30, 2010 | Whirlpool ACP092PR Air Conditioner
Raining on the food
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jun 02, 2010 | Whirlpool ET8MTKX Top Freezer Refrigerator
The chair was outside and got a small amount of rain on it. Now when we turn it on, the lights (that show battery charge) blink fast and it will not move. My dad is grounded until we can figure this out....
Hi. Count how many lights are flashing, it is showing a fault code. Let us know, or contact your local dealer. Check that the free-wheel levers are in the correct place. Good luck. Neil.
May 19, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Only half the screen is showing up the rest is black and there is no way to click on the black space or move it
Hi im Rain.
Ok there is a way to check if its the monitor or the video card is bad.
  • unplug monitor from computer
  • look for the monitors self test screen
If the self test screen comes up and you have a full picture. Then its your video card that is the problem.
If the picture is still the same after being unplug from the computer, then your monitor will need replacing or servicing.
Nov 24, 2009 | Lands Phones
Screen damaged in corner
Hi. you can replace this screen but, it would most likely equal the price of a entirely new set. The wall mount is a great idea as well. It will keep the LCD screen in a safe place.
Please rate and god bless:)
Apr 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Heater fan does not run
water may hav flooded your fan motor and cause d an elictical fault.
Dec 17, 2008 | 2000 Buick Century
Washing Machines Logo
14 people viewed this question
Dan Webster
Dan Webster
Sal De
