Question about Rheem Paloma Tankless Water Heaters PTG-74PVN Tankless RTG-74PVN
My paloma tankless water heater heats water fine. But there is an error reading of 1L on the display. I have flushed the unit many times but the error message stays. Is there a reset or should I continue to flush the unit even if it's working fine?
Check L1 error code on following site:
http://www.palomatankless.com/owners/homeowner+trouble.lasso
Posted on Feb 25, 2011
I have a Paloma PTG-74PVN-1 high volume tankless water heater installed in 2007. Recently, I am having hot water temperature problem, no error code is displayed, but it can not heat the hot water beyoun...
Even though you are not getting an error code, there are may be some diagnostics in the controller that can identify whether it's an electronic (controller/sensor) or a heat exchanger issue. I would contact Rheem tier-2 support.
Jul 01, 2014 | Rheem Paloma Tankless Water Heaters...
Code 1L on the pad, I flushed with pure venegar. for at least 5 hours the problem persist, help
open cover.. find buttons min/max press nim then press mas and then hold min and max presses for 5 seconds or so. Power off controller and power back on..You have reset your fault code til next time.
Jan 28, 2011 | Rheem Tankless Water Heater Main Remote...
Thermostat flashes IL ? Model PTG-53PVN
http://www.palomatankless.com/owners/homeowner+trouble.lasso#28-11
The Controller displays error code "1L."
There is a build-up of lime in your Paloma.
Contact your plumber to service the Paloma by flushing out the lime.
Also search u-tube for flushing lime out of tankless.
Dec 29, 2010 | Rheem Paloma Tankless Water Heaters...
I have a 1L error code. Can you help? I have a Rheem RTG-53 PVP. Tankless water heater. Works great. Except for the Error code.
Hi stevenandarl,
Contact Paloma/Rheem customer (800-432-8373) support; tell them the code you are displaying. Rheem will send you instructions via email if you feel you can perform this operation yourself. Or they will recommend a professional in your area to help you.
Mike...
Nov 24, 2009 | Rheem EcoSense by 7.4 GPM Tankless Water...
Paloma tank less water heater flashes code C4 13 and we have no hot water?how to fix it?
I had the same problem with my Paloma a year and a half after installation...contacted Rheem customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Nov 16, 2009 | Rheem Paloma Tankless Water Heaters...
Rheem Paloma  Tankless Water Heaters PTG-74PVN  Tankless RTG-74PVN Logo
287 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
