Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
OE Error on LG Dishwasher model LD-14AT2. Filters arent blocked and chord not kinked. Wont stop pumping water out in wash cycle. Seems to think there is still water in there when there isnt any at all. Any ideas as to what could be wrong?
  • 351 Answers
SOURCE: LG dishwasher model LD-14AT2
normally means not heating check element and use less soap
Posted on Mar 03, 2008
  • 489 Answers
SOURCE: LG LD-14AT2 SS Dishwasher.
The door frame is bent and will need to be inspected if further damage is done.  It's possible to fix but if the dishwasher frame is bent, then it's a total loss.  The frame is not repairable or are there any parts for it.
Posted on May 02, 2008
SOURCE: OE fault in Dishwasher model LD-14AT2
suggest you take the drain pump motor out and inspect. either a blockage or its defective.
Posted on Jul 11, 2008
  • 423 Answers
SOURCE: LD model LD-14AT2 dishwasher
Are you getting an error code displayed when this was happening?
How did you fix the problem?
Posted on Apr 07, 2009
SOURCE: LG Dishwasher Model LD-4120M Error 0E
I had the same endless problem and finaly put a cleaning product through with heaps of restarts and now the machine works perfectly. So anyone out there with the OE error should try this inexpensive solution. If it does not work you have not lost much. You may need to restart several times during the process and is a great pain but maybe it will solve your problem .
Posted on Apr 21, 2009
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
I have an lg 1415 dishwasher .. it started on a wash ,but stopped 2 mins in beeping with 'OE" flashing .water pooled at the bottom not draining. watt does "OE' mean .. and is it blocked ?...
Hi michelle_133,
The "OE" error code you are seeing, means "Outlet Error"
The drain pump is either clogged, or the outlet hose has been kinked.
- Inspect the Drainage hose at the back for kinks. - If any, straighten the hose
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it. It has small holes that **** water away after the main wash, and while rinsing. Foodstuff may be blocking these holes, also remember to clean the filter after every wash.
Kind Regards :-)
If you found this solution helpful, please rate it.
Jul 06, 2011 | LG Dishwashers
My LG dishwasher is stopping after a few minutes into the wash cycle with an error message OE and making a sound. The dishwasher tablet is still inside the dispenser and while there is water in the unit it...
Hi rebeccasolom,
OE means "Outlet Error"
The drain pump is either clogged or the outlet hose is kinked.
Kind Regards :-)
May 25, 2011 | LG 24 in. LD-12BW5 Free-standing...
My Lg Dishwasher , model 12aw2 , has an error message OE shortly after start up , dishwasher is over 6 years old , is this a simple fault to repair? or not worth it ?
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 11, 2010 | LG 24 in. LD-12BW5 Free-standing...
Instead of showinf a time my LG dishwasher (LD-2120w) has code: F on then during a cycle it stops and flashes 0E. I have found OE means to clean the filter which i think i have done, but the priblem is...
With an OE error, the next step is to follow the drain hose from where it connects to the dishwasher through the point where it connects to the drain.
Look for crushed hose, kinked hose. Then look for a plugged drain connection.
Please report back what you find. There are other things that ~could~ cause the problem. OK?
Aug 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error code OE
The error is DE - DRAIN ERROR , Not fully drained out in spite of 5 min. drain operation
Possible causes
¥ The Filter clogged.
¥ The Drain Hose kinked or blocked.
¥ The Drain Pump/Motor or circuit is troubled.
Possible solutions
¥ Clean the Filter.
¥ Remove the cause of kink or block.
¥ Replace the Drain Pump/Motor or repair the Circuit.
Jul 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error OE
thats a drain problem , blocked drain hose , drain pump stuck or burned , last case scenario electronic control
Jun 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
DISPLAYING OE ERROR CODE
What did the original poster with the OE error find?
An OE error = Dishwasher not fully drained out in spite of 5 min. drainoperation
Remove the cause of kink or block in the drain hose.
Remove the filter and confirm that there is no debris in the sump area, especially the drain pump outlet.
Check the wiring connections, especially in the wiring harness in the door panel. Look for "melting" insulation.
Measure the electric resistance of Drain Motor. (good=20-40 ohms) Replace the Drain Motor if out of spec.
Good Luck!
Jan 12, 2009 | LG 24 in. LD-12BW5 Free-standing...
Jun 15, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
193 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
