Question about Tippmann A 5 Standard Paintball Gun
Keeps blowing o rings - Tippmann A 5 Standard Paintball Gun
  • kov13 Jan 14, 2011
    Which o-rings, the CO2 o-rings or the ones in the gun
  • 396 Answers
If you are using CO2 switch to air. Also make sure the velocity adjuster isnt running
at the highest rate. Which specific O-ring are you blowing out?
Here is your manual.
http://www.tippmann.com/pdfs/products/A5/a5manual.pdf
Posted on Mar 14, 2011
I installed my Ring doorbell and set it up but it keeps blowing fuses. Help!
-Make sure correct fuse rating and make sure the power line never connect to any metal or frame.
Good luck and ring a lot
Mai Lor
Nov 03, 2017 | Cars & Trucks
Ihave 1991 k/q ,has blow by but doesnt smoke but keep running it will blow out oil alot have shut down,??
blow by is cause primarly from worn rings and worn bores. The fix is to bore out the cylinders and fit over size rings. The major reason for blow by is a faulty air filter system that allows the engine to be "dusted" in use.
Oct 22, 2014 | ATVs
I used compressor 3 wks ago and worked great.Now will not compress air above 25 psi.changed regulator OK,removed air intake filter,it has suchion.removed outlet tube,bloweds air.Oil in site glass.I did...
Mike:
If you have air blowing out of the oil filler cap, I would suspect that the piston rings are shot. The piston rings are supposed to keep the compressed air above the piston, and air seems to be leaking past the piston rings into the crank case.
Sep 17, 2013 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Clock fuse radio ele mirrors dvd player keeps blowing kia sedona
Same thing happened to me. My DVD player stopped working and the 15A fuse for Power 1 kept blowing. Turns out that there was a little metal ring that had fallen into my powerpoint connection on the dash. It was shorting out my DVD player. Removed the ring, installed a new fuse and DVD player is back up and running.
Feb 21, 2013 | 2006 Kia Sedona 2.9
Stanley n60 trigger blow by
Sounds like o-rings. Have you tried replacing the o-rings?
Feb 14, 2013 | Stanley Bostitch Coil Framing Nailer
How and or why would i get gas in my oil ?
hi,
your piston rings have rusted up and gas is getting through, usually from sitting outside in the rain. take the plug out and get some motor oil in the combustion chamber. change the oil and just put enough gas in it to get it started, get it running without load on low idle and when it stops blowing oil and undulating your piston rings have been freed. keep a fire extinguisher handy or hose. if it keeps blowing oil you will have to take it in.
jm
Apr 22, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Are bike is having a little smoke coming from the exhust pipe we think it might be the antifreez we just moved from florida our manual is packed away just need alittle advice
is it blue coming from the exhaust
is it a 2 stroke if its a 2 stroke blowing blue smoke its quite normal if its blowing to much your rings might need replacing keep an eye on the ((oil level))
if its a 4 stroke and its blowing blue smoke from the exhaust keep an eye on the ((oil level)) the rings might need replacing if its burning lots of oil and blowing blue smoke your rings do need replcing
hope this helps
Mar 02, 2011 | Geovision GV-650 BNC (GV6504) Video...
The 6.5 hp Briggs & Stratton engine that powers my 2550 elite pressure washer is blowing oil out the exhaust and air filter while it is running. Do you think this is a gasket problem or a piston ring...
It most likely is a ring problem as the gasket only keeps the combustion gases in and would leak around the head as a loud noise. Of course it could be the valves, but I doubt it as most of these engines are splash fed instead of pressure, so the only explanation is the compression ring is letting oil blow past.
Jan 03, 2011 | Briggs Stratton 020273 Elite Series...
The fuse keeps blowing for the ac
Does the A/C work normally before the fuse blows, or does the fuse blow right away? If it blows right away, you probably have an electrical short and you would need to ring out the wiring. Another thing to check is the ampacity of the fuse- make sure it is the right fuse.
Aug 21, 2010 | Ford Thunderbird Cars & Trucks
Why is the abs fuse keep blowing in 1999 mercury cougar?
Could be a broken ABS sensor ring at one of the wheels
Jul 23, 2009 | Mercury Cougar Cars & Trucks
Tippmann A 5 Standard Paintball Gun Logo
93 people viewed this question
Top Tippmann Sport & Outdoor - Others Experts
spank61
Tom Chichester
Are you a Tippmann Sport and Outdoor - Other Expert? Answer questions, earn points and help others
