Question about Garden
Hello, I have a Dewalt DP2800 Pressure Washer and cant figure out how to drain/change the pump oil. The model on my pump is RSV 3G30. There is a red cap on top of the pump with no level indicator. Thank You
5 Suggested Answers
  • 16 Answers
SOURCE: What kind of pump oil goes into the CAT PUMP model
Cat pumps make their own oil. You can purchase it at most Carquest parts stores. If the Honda is gas, 30w motor oil
Posted on Oct 12, 2009
  • 63 Answers
SOURCE: when changing the oil on
Normally you would add oil using the same hole that you were using to check the oil which allows the new oil to go into crankcase.
Posted on Sep 22, 2010
  • 57 Answers
SOURCE: I bought a troybuilt pressure washer used and i
if you left it sit for a while & did not turn the fuel tap off,it may have flooded and therefore the oil level would have risen causing the oil to over flow.
always turn the fuel tap off when not using your pressure wahser.
Posted on Dec 20, 2010
  • 397 Answers
SOURCE: what kind of oil is
Use 75-90 synthetic differential oil.
Posted on Jun 26, 2011
What oil to use
Your manual will say to use General pump oil GP100..or whatever DeWalt's number for that may be. See dewalt.com for their proper part number. From the pictures of that model I see on line, that is a General Pump and they have recommended Non-detergent 30w standard motor oil in the past. We like to use a non-foaming full synthetic 20-50w racing oil on these high RPM pumps.
Oct 20, 2012 | Dewalt DXPW4240 4200 PSI Direct Drive...
What type of oil do i put in the DPD3100?
In the Pump Dewalt recommends
DeWalt DP70 Pressure Washer Pump OilIn the engine Dewalt Recommends
SAE 10W-30 is recommended for general use
Jun 26, 2011 | Dewalt DPD3100 Gas Pressure Washer
Where do you add the oil on a DeWalt 3100psi pressure washer?
Hi and welcome to FixYa, I am Kelly
From reading everything I can find, i.e User's manual & parts manual the only thing you add oil too is the engine. The pressure pump does not have a liquid sump.
You can look at parts here detail D:
http://www.ereplacementparts.com/dewalt-dpd3100-pressure-washer-parts-c-1009_7440_7445.html
So too add oil to the engine you would remove the dip stick from the crank case located on the opposite of the side of the engine as the oil sensor.
I recommend you use 30 WT SAE oil for 3 oil changes then on the 4th oil change use an HD 30 WT oil. The oil drain plug is located in the center of the side of the engine crank case base. On the 5th Oil change switch back to SAE 30 WT oil. Oil brands are not really important. They all have to meet SAE the same standards to carry the label of SAE. (Yes you can use a generic 30 WT SAE oil )
Thanks for choosing FixYa,
Kelly
Dec 06, 2010 | Dewalt DPD3100 Gas Pressure Washer
Got a Dewalt 3800 PSI Pressure Washer with 4.0 GPM with a Honda GX 390 gas engine. Tipped it up to roll it out to my truck and got a big puddle of water with what looked like Pump oil in the puddle. Can...
Could very well be. Did you check the oil level and condition of oil? If its too full or if its light brown milky, then water has entered crankcase. Pressure washer pumps cannot stand to ever let run dry. Even a little. Also excessive idling will overheat pump if it doesn't have a thermostatic relief valve that allows some more cool water to enter pump.If it doesn't have one add one. Find your PUMP mfg and model number. IF it's pumping good now and no leaks, quick replacing the seals will save big future repairs. www.pressure-washer-parts.com has lots of info on many pump manufactures. Or get some seals from dewalt.
Aug 11, 2010 | Dewalt 3800 PSI Pressure Washer
De Walt pressure cleaner not drawing chemicals
pull the hose off at the end going into the water pump there is a screen inside of that fitting remove it and clean reinstall and try it again, sometimes the pressure washer has to be on low pressure in order to pull soap out of the bottle.
Nov 22, 2009 | Washing Machines
Model #1578961A. The pump pressure cuts in and
usually caused by a supply problem, make sure you have enough water comming into the pump and that the screen in the connection is clean
Nov 15, 2009 | Northstar Pressure Washer 3000 PSI
My DeWalt Gas Pressure Washer Model DPD3100 is
Hi
Just try the following steps
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Good luck
Regards
PCmania
Jul 05, 2009 | Dewalt DPD3100 Gas Pressure Washer
How to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
May 21, 2009 | Briggs & Stratton Pressure Washer...
Garden Logo
132 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
