Question about Moen & One Handle Tub & Shower Faucet
My Moens One handle tub shower shot out at me and i could not stop the water for nothing what would make it shot out
    Genius:
  • 1,015 Answers
If it is an older valve there is a small copper retaining clip that holds the cartridge in place. If this clip broke it could blow cartridge out or come out when you pulled it to turn it on.
If that is the trouble you can see the slot in the top of the valve body where the retaining clip goes.You will need to get a new clip and put the cartridge back in and insert clip to hold it. If you find that you have the hot and cold sides reversed simply turn the stem of the cartridge 180 degrees and you should be in business. Thank you
Posted on Jan 02, 2011
Old Moen shower diverter
You will have to replace the shower diverter button. Remove the handle, remove the faceplate, and the diverter will screw out. Any plumbing supply that carries Moen products will have a replacement button for your valve
Feb 23, 2014 | Moen Home
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
Danze opulence diverter handle does not work
you have to replace diverter....if its in the tub spout unscrew and go to lowes or plumbing supply and match up style and replace...use pipe dope and screw back on tight...good luck
May 01, 2012 | Danze & Single Handle Tub And Shower...
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
The single handle fauchet will not stop running water.
Replace cartridge and insure that the C clip is not missing.
Sep 11, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Water will not turn off
are the handle extensions on the cartridges all the way. i know sometimes the moens are a pain after you put the trim on to get them on and seated right so it actually spins the cartridge. also check the cartridge alignment the cartridges have little white tabs on the sides that correspond with a slot in the valve body if they aren't aligned it won't shut off either
Jul 31, 2009 | Moen 2919 Chateau Two Handle Tub and...
No water
the screw should be a phillips head or allen screw
May 28, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen & One Handle Tub & Shower Faucet  Logo
110 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
