Question about Sylvania G-Netbook
My sylvania is dead how do I do a system restore to factory settings dell says F12
    Genius:
  • 1,267 Answers
If this is the Sylvania SYNET07526, you turn it over on the back and find a small hole 1in diagonaly from the right lower corner. Insert a tooth pick in to the hole and depress the micro switch for about 10 seconds, mind you this is when you have the charger inserted fully into the machine.
Posted on Jan 02, 2011
How restore a D400 to factory setting
Reboot the system and before Windows loads press the F12 key to get a boot menu. Choose the restore option. If that is corrupt or missing, try this:
http://www.ehow.com/how_6547558_restore-dell-latitude-factory-settings.html
Jun 30, 2014 | Dell Latitude D400 Notebook
Im trying to restore my dell pc back to factory settings its running vista f8 is not working i can only use f2 and f12
I would recommend using the Dell factory restore DVD. It probably didn't come with your computer (companies save money by not shipping a DVD with the computer). You can order it from Dell and it will probably cost less than $20.
Many times the restore function by hitting a special function key at startup becomes corrupt and doesn't work.
I'd opt for a new DVD to use.
Apr 18, 2012 | Dell Computers & Internet
Im trying to restore mt dell pc..back to factory settings its running vista f8 doesnot work ive only got f2 and f12
F8 is not the key you would press to get into Factory Settings or System Recovery as it is called. F8 gets you into different boot modes such as Safe Mode, or Restoring your last good Boot settings.
The key most manufacturers use to get into Recovery is F11, but to be sure which key to use either tell us the model of your Dell or go look it up yourself by reading the owners manual.
Get onlineand got to www.google.com In the google search box type: "DellSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals and Documents.Once you find the manuals search through them for Factory Settings or System Recovery. It will tell you which key to hit when you press the power button.
I want to restore my dell laptop
HIif you kept your recovery cd's put it in cd drive and restart the laptop (in post screen before starting windows shows f10 or f12 for chosing boot sequence or device ) then follow the instruction that recovery software gives yougood luck
Nov 27, 2011 | Dell Computers & Internet
I am trying to restore my Dell Inspiron 6400 to factory settings as I have a Trojan that I cannot get rid of. However when I press ctrl f11 nothing happens and my laptop continues to boot to the OS. I have...
If you want to reformat to factory condition, then press Ctrl + F11 at start-up when the blue bar comes up with "Dell.com" on it. If you miss it then just let it start up, then restart and try again. If it still does not work, press F12 at startup and select recovery option. Please note, if you have deleted the Dell Recovery Partition this will not work for you. You will need to reformat by inserting your Operating System CD at Startup and booting from that (F12).
Jan 13, 2010 | Dell Inspiron 6400 Notebook
Hi, Ive been having problems with my laptop Dell Inspiron 1545 i was told to reset it to factory settings, how do i do that?
Hi i'm Rain.
some of the dell models have a built in factory reset .
It will be either F9 ,F10 , F11 or F12
If this option is not avalible to you you will need to go to start then all programs then you will need to go to accessories . In accessories click system tools then system restore.
Follow the on screen instructions.
Select a date before the problem accured. click next and allow the system to restore itself.
Nov 23, 2009 | Dell Inspiron 1545 Notebook
Restoring my dell to factory settings
If you want to clear off all of your files and reset it to how it was when you first got it (Factory settings), hit CTRL + F12 when the computer is booting up.
See this link.
Jul 13, 2009 | Dell Dimension 3000 PC Desktop
I have vostro model A840 .. i cant install my wireless network driver..that is wlan 1395 driver.. it says ur hardware is not compatible.. i installed both xp and vista and checked
hi,
was it working when the system first came to you, if so then what you can do is dell factory image restore, but that will wipe off everything including your data on the system so you should backup your data before doing dell factory image restore, one more thing it can only be available if you haven't done any clean os install on the system, to access dell factory image restore you should start tapping F12 key at the blue dell logo and then from the one time boot menu select dell factory image restore.
Further Queries are welcome
Feb 21, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell laptop inspiron 1000
Put recovery disk in the CD drive. On reboot, hold down F12 key. You should get a choice of drives to boot from. Make sure the first two are in the correct order:
1. CD-ROM (optical drive)
2. HDD (hard drive)
then press F10 to save and exit.
Now the laptop should boot correctly from the recovery disk.
Jan 06, 2009 | Dell Inspiron 1000 Notebook
Restore factory settings on a Dell Latitude C510
theres a solution to this. all you do is. hold the ctrl for 20 seconds then as you.
turn power on press f-1 or f-11 botton press f-11 botton 16 times semi guickly.
and follows the promps worry not about any files or music being missed.
theyll all be there.
Nov 05, 2007 | Dell Latitude C510 Notebook
Sylvania G-Netbook Logo
721 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
