Question about Apple iPod touch
Since my ipod won't charge, how do i remove the battery?
    President:
  • 1,285 Answers
Follow this you tube link (how to open the ipod)
http://www.youtube.com/watch?v=t2107bzNEr8&feature=related
for batteries
if you order battery (you will also get some tools to open the ipod) do not use knife or screwdriver this will scratch the unit
http://www.ipodbatterydepot.com/index.asp?en=google&maingroup=highvolume&adgroup=ipodbatteryreplacement&ad=2&gclid=CKbYyJPYmqYCFU1-5Qod0xd6nA#
note: be careful wires are very close together so do not pull apart as quickly
Posted on Jan 02, 2011
Tip
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
on Dec 06, 2017 | Computers & Internet
Dead not connect charging
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 18, 2012 | Apple iPod touch Second Gen (8 GB,...
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
Charge the battery
Aug 13, 2012 | Apple iPod touch Second Gen (8 GB,...
Sylvania imode ipod docking station plays ipod but won't charge it - why?
ipod touch has a light piece of plastic on bottom where it connects to the dock youtube has a video on how to remove it softly with a razor blade and once it is removed it will work properly although to be played through stereo i must have my ipod touch 4th gen on airplane mode
Jul 18, 2012 | Supersonic Audio Players & Recorders
My ipod wont charge
Hello, welcome to Fixya!
If your ipod won't charge, the fault should either be from the battery or from the means by which you are charging it.
If the battery is very weak, then it might not come-up when using charger or PC to charge it. Leave the ipod in the charge for about 6 hours and it should come up if the battery is weak.
But if it doesn't come up, then you have to check your charger. Test your charger with a friend's ipod. If the charge works with your friend's ipod then it means your battery is the cause of the problem.
The essence of the above test is to diagnose and get to the root of the problem. So that a precise/concise solution can be proffered.
I hope the above is clear. If not, please let me know.
Regards.
Nov 17, 2011 | Apple iPod touch 3rd Generation MC086LL/A...
My ipod wont charge when i plug it in
Regards.
After charging your portable media player overnight, you turn it on only to find that it is reporting a low battery. Seconds later, it shuts off automatically. What might be wrong
Ifthe MP3 player battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Apple iPod shuffle MP3 Player
Ipod not charging
hi Unpopster.
these links might help you find out why.
or this one.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices.
Dec 06, 2017 | Audio Players & Recorders
Apple iPod touch Logo
22 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
