Question about Garden
Lawn mower victor vc40 quattro, idle goes up and down! is it the carb?
    Novelist:
  • 144 Answers
Yes this could be the carb that needs adjusting, but it could also be the governor or both the carb and the governor. You could try adjusting the low speed mixture screw by turning it counterclockwise 1/8 of a turn at a time 3 or 4 times and see if it helps, (remember where it is so you can return it to this position if this does not work) or try it clockwise 3 or 4 times. That is about all I can suggest for now. Adjusting the governor is too hard to try to explain to you. I hope this helps a bit. Best regards and good luck.
Posted on Jan 02, 2011
Craftsman lawn mower 6.5
check for water in gas if no water sounds like you got a bad carb rebiuld it again or take it back ask for another one that yours is bad
Aug 28, 2014 | Garden
Tecumseh lawn mower idle surge
clean air filter and the carb use non ethynol gas
May 10, 2014 | Mtd 22" Yard Machine Push Mower
Toro GTS 6.0 hp idles up and down
Excess air or not enough air. Replace air filter. Spray outside of carb to clean & ensure choke movement is smooth. Water in gas may cause this also. Flush out tank, refill with fresh gas, always use Stabile.
Jul 31, 2012 | Toro Power Lawn Mower
Have a 4.0 quattro Briggs and Stratton lawn mower. Starts up great and doesn't stall out. Has this annoying surge and slow down of motor. Removed gas from tank and sprayed some gum remover in tank and...
it does sound like a carb issue it may need to be rebuilt also check your fuel line and if you have a fuel filter check the filter clean the gov. assembly with carb cleaner
Jul 30, 2012 | Garden
Idle seeking up and down
Hunting on engines is usually due to dirt in the carb main jet, remove the carb
, remove the float bowl and blow out the jets and fuel channels.
May 18, 2012 | Toro Power Lawn Mower
How do i adjust the carburetor for the idle
some have a small screw on the carb next to the throttle plate
Apr 26, 2012 | Ariens 21 In Classic Walk Behind Push Lawn...
Lawnmower engine idling to low
First, follow your throttle cable down to the carb. Locate the clamp that holds the housing in place and loosen it just enough to move the cable. Start the mower and adjust the idle by the screw that touches the same plate that your cable hooks to. Then push the throttle control to idle and retighten the cable clamp.
Apr 26, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Lawn mower will not stay cranked unless you keep pouring gas into
common problems to all older lawnmower, lots of dirt and dust the mower goes through and ages. I would first start by taking the carb apart and clean the filter with soap and water, allow it to air dry. also carburetor prob need rebuilding or replacing. Pick up some Carburetor cleaner at any auto part store and spay it down the carb, dont be afraid to spray allot in there and let it dry for 1/2 and hours. carb tend wear and parts need replacing just like any engines. 99% of the time lawn mower carb goes out before the engine will and common problems with all lawn mower. If you not mechanical incline or dont want to rebuilt it, just buy the whole new carb and replace it, fairly cheap easy to replace and will last you another 10 + years or more. www.briggsandstratton.com
Sep 01, 2009 | Omega Rear Drive Wheel Snapper Mowers
Briggs & Stratton Quattro lawn mower engine. Runs rich and unevenly. Suspect carb and have used sprey carb cleaner. Any suggestions??
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Jun 05, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
129 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
