Question about Toshiba MK8026GAX (hdd2191) 80 GB Hard Drive
THE HARD DRIVE ON MY COMP IS MK8026GAX, MY QUESTION IS,WHAT CAN I UPGRADE THIS TO ON MY POWERBOOK G4 ALUM 15" WITHOUT CHANGING ANYTHING?
3 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Posted on Jul 22, 2009
  • 1768 Answers
SOURCE: i can't find for toshiba
Please provide more information as to you issue such as :
1.Have checked the user manual 1st?
2. Did receive any errors when connecting the drive?
3. if this is an internal drive > did you check to see if you have the cable installed correctly> that is is pin 1 connected > is the data cable properly installed.?
Please give detailed information as to your issue to better assist you in your resolution of the problem you are having.The more information given will help
determine the resolution and guide you to the proper fix for your issue.
Thank you.
Posted on Mar 18, 2011
Sims 3 wont install onto my powerbook G4
Sims 3 will not run on a mac that isn't using an Intel based processor. You will have to upgrade from a Power-PC processor in order to use the latest version of sims.
Oct 15, 2012 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Want to free up space on my internal hard drive (Apple PowerBook G4) without
Mac do not waste space, I recommend you to use an external hard drive. Try to find one with twice capacity that your computer's hard drive.I mean, if your computer hard drive is 500Gb, then find an external drive with 1Tb
Oct 01, 2012 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
I changed the hard drive in my powerbook g4 17in how do i in stall snow leopard on it it has a folder with a flashing question mark and finder
It seems that snow leopard is only installable on macs with intel processors, and yours is PowerPC.
see more here: http://www.apple.com/macosx/specs.html
Aug 23, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Powerbook G4 is not working When I put a CD in 2C the computer spits it back out without reading
You need to replace the optical drive. Go to web site of Other World Computing and order a CD/DVD super drive which will burn/play discs and even burn on dual layer discs. Cost about $80 US plus your free labor to install the thing.
Mar 08, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
MacBook won't recognize my Lacie Rugged Hard Disk. Disk utility will see it but won't verify it nor will it repair it. says it needs to be reformatted yet it won't even let me initialize it. it is brand...
Is your MacBook as fast as the Lacie Rugged Hard Disk is?
Because solid state drive wasn't available on MacBook Pro at the initial time when it launched. Hard drives on all current Apple laptops are equipped with Sudden Motion Sensor technology. In fact, the Apple laptops that came with Sudden Motion Sensor are: All Intel-based Apple portables such as the MacBook, MacBook Pro, MacBook Air, PowerBook G4 computers starting with PowerBook G4 (12-inch 1.5GHz), PowerBook G4 (15-inch 1.67/1.5GHz), PowerBook G4 (17-inch 1.67GHz), and iBook G4 computers starting with iBook G4 (Mid 2005) have Sudden Motion Sensor technology. You MacBook may not have come with that technology that could be the reason you are unable to connect it.
Sorry mate... too many limitations on
Feb 24, 2010 | LaCie Rugged All-Terrain (301017) Hard...
How do i back up a power book g4? What application do I need to do the back up?
Suchisart,
If you want a stand alone backup solution, you can download a free program called "Carbon Copy Cloner" and purchase a USB 2.0 external hard drive. You can use the CCC software to backup the entire contents of your Powerbook's hard drive or just selected files to the external USB hard drive.
If your Powerbook is unable to boot into OS X and you need to recover the files that are on the internal hard drive, you can boot the Powerbook into "Target Disk Mode" and transfer the files via firewire cable to another Mac. To do this do the following.
  1. With both Macs off connect them with a firewire cable.
  2. Turn on the Powerbook and hold down the "T" during startup.
  3. Once the large icon shows up on screen your in "TDM".
  4. Turn on the other Mac and login to your account.
  5. The Powerbook's hard drive should mount on your desktop.
  6. You'll be able to transfer your files from the Powerbook's hard drive just like you would an external hard drive, thumb drive, etc.
Don't forget to vote and leave us some feedback. :)
Thank you,
Scott Computer Services http://www.scottcomputerservices.com
Feb 16, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
PowerBook G4 discs won't get snatched in discs just float freely
Yes, it sounds like the disk transport mechanism is shot.  You can try www.macsales.com for a replacement internal, but those are usually a) pricey and b) a REAL pain to install (LOTS of small parts and such) - www.ifixit.com has real nice tear-down guides for just this purpose.  Or, for lots cheaper, you could just use an external drive.  Good chance to upgrade to a faster drive/one with more features.  Go for a bus-powered one to cut down on the extra cords.
May 27, 2009 | FastMac (APP-5693) for PowerBook G4...
Powerbook g4 15 not turning on
Something is wrong with the operating system. If there is a flashing folder with a question mark, then it might be with the hard drive as well. If you just get that warning, then you may only have to reinstall your operating system (OS X). Get your CD/DVDs out and insert the OS X disk. Hold down C when you start the computer so it will start from the disk and not from the hard drive. After the startup program has loaded, you can try to check the hard drive and repair permissions and such to see if that works, or you can just reinstall the OS. Good luck.
Mar 21, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Toshiba MK8026GAX (hdd2191) 80 GB Hard Drive Logo
61 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
