Question about HP Photosmart D7260 Printer
HP photosmart printer is offline- how to correct
    Novelist:
  • 169 Answers
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Posted on Feb 04, 2011
hansola
  • 279 Answers
SOURCE: the HP printer is connected but the icon shows "offline"
Go to control panel, then select printers. Then, from the list of printers (if you have more than one), right click on your printer and make sure "Use printer Online" is checked.
Hope this helps.
Posted on Jan 12, 2010
oldnovii
  • 667 Answers
SOURCE: Photosmart 2575 printer is offline - won't print
Hey jonboy - You do not want to delete it. It is automatically installed with Vista. In simple terms, you know when you go to print something and it asks you questions like print all pages, print page 1, etc? Well XPS basically is there for so when you go to print, you have the option of printing to a file instead of paper. You've always had that option ( whether or not you knew it) but this is just a new way of doing it and that's why it's listed under printers. It's sort of like a virtual printer. I'll say no more about that and just hope you understood what I said. As far as the other printer, it's already selected as default, go back in where you found the printer status, right click on your Photosmart and click on use online. That should do the trick.
I hope you understood this stuff. If this solves your problem PLEASE rate this as fixed. If you still have a problem, DON'T RATE it yet just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Posted on May 09, 2008
dominusnex
  • 15 Answers
SOURCE: HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Posted on Dec 14, 2008
bravsman
  • 94 Answers
SOURCE: "printer is currently off-line. offline" use a mac
check the usb cable of printer try to reconnect it and make sure you use usb port in your printer properties
Posted on May 25, 2009
SOURCE: MY PRINTER OFFLINE
I don't have a solution for this problem. I have a comment. I have the same types of issues with my HP. I hate HP. Why is it that we can design software to remotely fly fighter jets but we can't get reliable software to print wirelessly? I am now going to throw my HP Photosmart C4580 All-in-One in the road.
Posted on Aug 04, 2010
Printer hp photosmart 2600 is offline
Please download and run the HP Print and Scan Doctor from www.hp.com/go/tools
Dec 03, 2012 | HP PhotoSmart C4480 All-in-One Printer ...
I have a new HP Photosmart Plus b210. I have installed all of the software, connected to my wireless router, & enabled printer sharing. It still will not print from the laptop. When I click on the...
I assume you fellow the steps in the manual and install everything correctly. We had the same problem on our hp printer. Sometimes, if you install Windows/software updates, it will put your printer offline. The problem will disappear once I restart my computer.
Feb 28, 2011 | HP Office Equipment & Supplies
How do I get my hp photosmart 7660 back on line?
Power off the printer and then unplug the printers USB cable from the PC. Now turn on the printer and plug the USB cable back into your PC. This should correct the issue. You can also go to "Control Panel" and select "Printers and Faxes". Then right click on your printers icon and see if it says that the printer is offline.
Hope this helps, best of luck..
Nov 19, 2010 | HP PhotoSmart 7660 InkJet Printer
My hp printer works with one computer wirelessly (windows xp) but with other one says "offline" (windows 7). Any suggestions?
Right click on the Printer icon which Says Offline,
Click on Troubleshoot
Continue with the T/s process and it should resolve the Issue
Jun 25, 2010 | HP Photosmart C6180 All-In-One InkJet...
The HP printer is connected but the icon shows "offline"
Hope this helps.
Jan 12, 2010 | HP Photosmart Premium C309A All-In-One...
How do I correct printer set-up when it is offline for a HP Photosmart C4580 All-in-one, Scanner, copier There is a problem with current printer set up. How do I correct?
check whether the printer is connected to the computer properly and is it powered onn >>
go to the printer folder and look for the name of the printer >> right click on it and you will get an option to use the printer online and i hope this is the best thing that you can do ............................. Thank you
Oct 13, 2009 | HP Photosmart C4580 All-in-One InkJet...
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Photosmart c4580 goes offline. using in wireless mode
My HP photosmart c4580 will print from my computers via USB but anytime I try print wrelessly it tells me it is offline. After all the problems I have had with this printer going into deep sleep mode and the patch updates which seem to eliminate this problem I am now burdened by this,
Please help..
Jun 29, 2009 | HP Photosmart C4580 All-in-One InkJet...
Good Day,
One thing you can try instead of deleting the doucment writer is to change the default printer. You can do this by right-clicking on the HP printer icon and selecting "set as default" from the drop down box. Also try turning the printer off and back on aswell as restaring the computer if you have'nt already. Did that printer ever work from that computer? How is it wired, by "switcher" do you mean a shared printer through you network(was printer sharing configured properly), or an A-B printer switch. Please clarify
Hope this helps for now
Jul 01, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart D7260 Printer Logo
262 people viewed this question
Seeker5211
Seeker5211
