Question about Dryers
Maytag Electric Dryer will not run. Start button sometimes gives a momentary low pitched hum then dies. Motor wont start. Door is closed power is on to unit.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Try this, tape the button down press start and give the drum a push to see if it will spin. If you can jump start it that way, you will need to replace the motor.
Posted on Jan 02, 2011
What causes Electric dryer to not start & run
Open the door and depress door switch have someone activate start button when humming rotate drum if it starts and continues to run replace motor
Apr 04, 2015 | Dryers
I have a maytag dryer that sometimes when I hit the start button will start and run for only a few minutes and stop and wont start again for a while and does a humming noise when it does star why?
Sounds like the motor is going into thermal overload (Getting hot) it may be caused by the motor itself, or could be overloaded by bearings or fan etc
Jul 28, 2014 | Maytag Dryers
Dryer drum needs several manual pushes to start
or just a bad belt cheap but labor intensive
http://www.youtube.com/watch?v=7OVBi0LcrzQ
Apr 29, 2013 | LG DLE2532W Electric Dryer
Drum wont turn.pust start and hear a buzz but drun wont turn
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Oct 01, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
MAY MAYTAG DRYER WONT START I HAVE POWER WHEN I PRESS THE START BUTTON IT SOUND LIKE IT SHORTED OUT
HI
Need to know what the unit does, Buzz, nothing? Because if it buzzes it could be a clogged blower or bad motor, its important to know this information.
Please get back to me
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 08, 2011 | Maytag PYE2300AY Electric Dryer
Dryer motor hums but does not turn when start button is pushed
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 24, 2011 | Maytag MDG6000 Dryer
My neptune dryer sounds like it is going to start but then fails
sounds like a bad motor. when it hums when you push start, open the door. put a piece of tape on the door switch to hold it in. at the same time, push the start button and turn the tub with your other hand. if it starts, this only confirms it is a bad motor. the motor will need replaced. good luck. shane
Jul 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't start all the time. can hand start unit.
hate to be the bearer of bad news but it sounds like ur motor is going out. Had this happen to my last dryer. If this is the case it will eventually just stop. Try running it without any laundry in it. if this works, then load it and see if it still works. (poor little motor has to work a bit harder with a full load) good luck.
Feb 17, 2009 | GE DBXR463EBWW Electric Dryer
GE Dryer DWSR473GV0WW periodically just hums when turning on switch
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Mar 28, 2007 | GE Profile DPSB619ED Electric Dryer
Dryers Logo
60 people viewed this question
Top Dryers Experts
