Question about Disney Lorus Rare Musical R2306AX Watch
I just bought an older Lorus Disney Mickey Mouse Musical watch V422-0010 with a box behind this number thia square was around the letters ZO. I cannot get the watch to work. It says, "After installing a battery. Short-circut the AC terminal and the battery (+) surface, with tweezers" First off, where would I find the AC terminal? second off, How will I know it is working? It has a plastic covering that holds the battery in. Please help.
    New Friend:
  • 3 Answers
Shorting the AC terminal is only required to "reset" the watch. The sound/alarm function won't work until the metal backing has been reseated... it provides a circuit connection to the battery for the music board. You do not need to short it to restore the alarm/sound function, but if the sound is weak/scratchy, you may need to.
Posted on Feb 22, 2015
    Problem Solver:
  • 7 Answers
There is no CR920 3 volt battery and especially will not work for any Lorus watch. There is the SR920SW and SR920W series 1.55 volt silver alkaline cell.. 9 mm diameter x 2.0 mm height is an impossible size for this old Lorus watch.
Posted on Feb 20, 2013
5 Suggested Answers
guru_fixya
  • 944 Answers
SOURCE: what battery do i need
CR920 3V + is the battery you need to buy.You can buy any A+ 3v battery it will be of same size.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 08, 2010
gemineye61
  • 831 Answers
SOURCE: i have a lorus mickey
You may need to have a local jeweler who has a watch press to put it back on, If you put to much pressure on the inside of the back, it may be warped. A knowledgeable jeweler should be able to fix that issue also.
Thank you for contacting FixYa..
Jewel
Posted on Aug 31, 2010
  • 2501 Answers
SOURCE: I have Disney Mickey through the years watch and need to change t
Is it worth taking it to a professional?
Posted on Dec 28, 2009
  • 23 Answers
SOURCE: need to replace battery of
Try to find a watch repair shop (sometimes called clock & watch shops). Also, many jewelers replace batteries and do watch repair.
Posted on Jan 13, 2011
Manual for Lorus mickey dual musical. V422-0010.where can I get one?
Try Googling (lorus)(V422-0010)(manual) without parens OR contact Lorus directly.
Feb 02, 2018 | Lorus Watches
I have a mickey mouse watch and I can't set it. It is running. It is a Lorus with the numbers vg91 6000 Z0 call 256-757-1533 Thanks
If any analog watch will not set and it is running, most likely the set wheel (gear) of the movement is damaged and the entire movement must be replaced. The wheel alone is not possible to replace.
I recommend visiting or contacting your local Certified Master Horologist to attain what is usually a free estimate or quote on the replacement of the movement.
Feb 23, 2011 | Disney Watches
Installed battery in lorus musical watch and nothing.
mcdevito75 here, A quartz mechanism can go bad just like a light bulb, depending on the watches age, wear etc. If your watch was stored for a period of time with a dead battery in it, that dead battery could hve leaked, ruining the mechanism. If your watch worked fine and the battery just went dead, make sure the battery contacts inside the watch are clean, use a Q-tip dipped in Alcohol and gently clean the battery contacts, press the button for the music part of your Lorus and make sure those contacts are clean and are meeting once the button is pressed, this you can see with the back cover off the watch. Makes sure the battery is installed correctly, and that the new battery number is the same as the old battery number. 364 and 371 are popular batteries for Lorus musical watches, even though your new battery is new, it can still be dead, who knows how long it was on the store shelf?? also, double check as some Lorus Musical watches have 2 batteries, 1 battery would be rather large ans sitting just under it"s hold down bracket see, as soon as you remove the back cover, if so, that battery must also be replaced. I have an old Mickey Lorus musical useing a 397 battery just 1 but my Lorus is burnt out. If all this fails, I would look for a small watch repair shop in your area and have them look at the watch for you.
Feb 18, 2011 | Watches
My gold Mickey mouse Lorus watch was opened a part damaged by the person replacing the battery. This is not a digital watch, but has nthe mouse with hands and a second wheel at bottom.
You are probably going to have to look for an identical watch for parts.You might try this site:
http://www.esslinger.com/watchparts.aspx?gclid=COCr3t2F9KUCFcIKKgodgiARnA which is parts for watches. I'd have a look on ebay as well for a watch that is not working. Of course it does depend on the part you are looking for. I am also wondering if the inner parts for another Lorus mickey moue watch might fit, but maybe you don;t wish to change it out from the original.
Dec 17, 2010 | Disney Lorus Out of Production Collectible...
Need to get watch repaired can you help me find a place to repair it
mcdevito75 here, It would depend on what is wrong with your Mickey Musical watch. I am in the repair service directory at the bottom of this page, I am Mike at the RITE TIME BASICS in Florida and I do some work on the 40"s, 70"s and 80"s Mickey watches. Or you try to look for a small watch repair shop in your area and have them take a look at your Mickey watch.
Jul 06, 2010 | Disney Adult Gold Musical Mickey Mouse...
Cant get old watch to chime
Instructions are on the inside of the back cover: 1. short circuit AC and the battery clamp. 2. the hands will rotate once clockwise 3. in the chime mode, pull out the crown and set the hands to the 12:00 position 4. Return the crown to normal position, change to time mode and set the desired time
Jul 06, 2009 | Disney Lorus Rare Musical R2306AX Watch
I have a Lorus NX11A multifunction watch and have no manual. I have been on the Lorus website but it might as well be written in Japanese
mcdevito75 here, I would imagine this is a Mickey Mouse Lorus watch by the picture supplied. If it Has DAY / DATE function, here"s what to do, --- To set the DAY, pull the stem out to set, keep turning the hads till you rech the day, then push in the stem. To Change the DATE 9 number) slip your fingernail just under the stem and lift it to it"s first position (notch) this should allow you to change the DATE (number) without haveing to turn the hands so many times.
Jun 24, 2009 | Disney Lorus Out of Production Collectible...
Can't get to work.
I have a lorus rvs001. Silver with black band. The instruction booklet says it takes a SR920W. Seiko Maxell or Sony.
Apr 13, 2009 | Watches
Disney Lorus Rare Musical R2306AX Watch Logo
1,048 people viewed this question
Top Disney Watches Experts
George Scott
George Scott
Are you a Disney Watch Expert? Answer questions, earn points and help others
