Question about JVC AV-32D302 TV
My remote control will not work on my TV. I have changed the batteries and tried a couple of universal remotes also with no luck. Any suggestions as to what the problem may be?
    Novelist:
  • 129 Answers
You can test your remote using a digital camera. Your phone camera will do.
Turn on the camera, point the remote at the camera and look at the screen. Press a button on the remote. You should see the LED light up. It this happens, the remote is working.
Your TV has a sensor that can see the LED's flashes. It may be defective.
Try unplugging the TV for a minute to reset the processor, that may clear the problem.
Turn off any flourescent lights or any recently added lighting to me sure that is not affecting the remotes operation.
Remove the batteries from any other remotes present (in case one is transmitting some information)
Hope these tips help.
Good luck.
Posted on Jan 02, 2011
Trying to match up a triantianyong TV-139F universal tv remote to this LCD TV DVD combo.
Search Results
    Universal Remote Controls - Encompass Parts
    https://www.encompassparts.com/staticlist/Universal_Remote_Controls
    TVs made since 1988. Works Mitsibushi . TVs only. Will not operate. TV/VCR or DVD Combo units. ... fully operate yout TV. Full function replacement remote for ToshibaTVs made since 1988. ... 2004-2005 LCD TV's. ON/OFF, CHANNEL +/-, ...
    Universal TV Remote ' eBay
    www.ebay.com/bhp/universal-tv-remote
    eBayUniversal Remote Controller 6 IN 1 TV DVD VCR Satellite Receiver Cable Box Audio... control for Samsung LED/LCD TV is the lastest product, easy to operate and ...damaged or needs to be substituted, or when you dxxire to have a combi.
    Codes For Universal Remotes ' Universal Remote Control ...
    codesforuniversalremotes.com/
Feb 05, 2016 | Universal Televison & Video
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn't help....
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Mar 24, 2013 | Samsung TV Remote Control
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Try this:
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Please rate if Helpful.
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
TV IS NOT RESPONDING TO REMOTE. I'VE CHANGED THE BATTERIES AND HAVE TRIED OTHER SAMSUNG REMOTES THAT WORK ON MY OTHER TVS. ANY SUGGESTIONS...
Sounds like problem is with TV. Make sure the remote sensor on the TV is not blocked, it is located at the lower right part of the front of the TV.
Dec 12, 2010 | Samsung BN5900696A Remote Control
My remote control will not work despite putting in new batteries. If Lkeft for a few hours it will work a couple of times before not working again.
Maybe time for a new remote. But first, try some different batteries and make sure there is clear path from the remote to the unit. If you have a universal remote, program it for the TV first and try it. If it works, your other remote should be replaced or use the Universal remote to control the TV.
Oct 12, 2010 | Sony KP-61HS30 TV
Universal Remote Compatability
Usually, any universal remote works on just about any tv. To find the codes, I suggest googling the remote model number +codes, or try to find instructions for an "auto search" so you don't have to keep punching in codes. Good luck! Der Strom
Apr 06, 2010 | Coby TV Remote Control
Samsung TV remote. I noticed today my TV remote wasn't working. I changed the batteries and noticed there had been some leakage from the AAA batteries. Since changing the batteries the 8 buttons on the top...
Giving you some hints. Battery leakage is one enemy of tv control and other remote control. They can corrode your battery spring contact, give contact bridges with neighboring tracks that can cause erratic behavior of your remote.
Some repairs can be done but doesn't guarantee success. First is try to clean the corrosion on battery contact = no power usually. Erratic behavior cause by contact bridging = battery leak residues.
Opening a remote control. Some have screws on its small foot. Covered by a rubber or sticker. Some are notch clip in strategic location you have to fry that one by one, opening first on its weakest side. In some don't want to be open.
Cleaning the board by a soft eraser is one way. After you open the remote. Commonly the button area where contact takes place.
If the first procedure and cleaning doesn't work. Buy new remote or use universal remote controller.
Aug 23, 2009 | Samsung TV Remote Control
RCA DVD/TV remote not working
You may have corroded battery input terminals in the remote control. Try using some electronic contact cleaner to clean the contacts. If that does not work try putting in a new set of batteries. If this does not work, you will need to get a new remote control.Having it repaired will cost as much as getting a new one. I hope this information helps you with you problem with the remote control. Thank you for using FixYa and have a nice day.
Feb 16, 2009 | RCA 3-Device Universal Remote with...
Toshiba TV Remote Control not working
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Nov 17, 2007 | Toshiba 36HFX71 36" TV
JVC AV-32D302 TV Logo
142 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
