Question about EZ Dupe (EZD3TDVDNEC) DVD-RW Burner
I put a dvd in and it says source disk empty...
  • 20 Answers
Which writer on the duplicator ejects when the error message "Source Drive Empty" appears on the display? If it is one of the writer drives, the source drive was changed to one of the writer drives. In order to solve this problem quickly, feel free to give us a call @ 866-686-8868 between Monday-Friday, 8:30A to 5P, PST. Thank you for your inquiry.
EZ Dupe Technical Support
Posted on Jan 04, 2011
  • EZ Dupe Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Jan 02, 2011
4 Suggested Answers
  • 3 Answers
SOURCE: SOURCE DISK EMPTY-- when there is master disk in there
The solution to this is simple. On the menu when you see that the # of MB is 0MB. Press the Arrows that change the menu option to #8 Select Source. Change this back to your original DVD-Rom or RW drive.
Posted on Dec 20, 2009
  • 3 Answers
SOURCE: Machine won't duplicate CD or DVD...A good disk is
  • 3 Answers
SOURCE: i'm having the exact same problem...
When trying to copy the message reads source disc empty
Does the disk drive play the disk? If not, the drive could be faulty. If not, then the disk can bec copy protected
Jun 13, 2014 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
Target disc not empty
Target disc ( this is what you've selected to burn TO) is not empty(is not a blank disc). You should try a different blank disk, or else you have your source and destination backwards.
Nov 16, 2012 | Acard Technology (ARS-2030LD) DVD±RW...
Acard duplicator - 'Source drive not ready'
> source drive not ready
When you push the button to open/close the drawer, does it work,
i.e., is there electrical power reaching the drive?
Did you put a disk into the "source" drive?
Is the same disk recognized when you put that disk into any other computer?
If so, then the "source" drive is damaged, and needs to be repaired/replaced.
Jul 18, 2011 | Acard Technology 15 CD DVD Duplicator...
When I put the disc in to be copies and then the blank discs i press the green start button and it display target drive not ready. How do I get it to copy onto the other discs??
One of the "target" CD-writers is not working -- either the "data" cable is not connected, or the "power" cable is not connected, or the drive itself (either the "spinning" motor, or the "laser") has failed.
Presumably, you don't have to fill "all" the trays, in case you only want to make a few copies of the "source" disk.
So, make a few attempts, with the "source" disk in the "source" drive:
1. put a blank disk into the 1st "target" drive,
leaving the other targets "empty", and press the button.
If it works, then the 1st target drive is OK.
2. put blank disks into the 1st and 2nd "target" drives,
If it works, then the 1st and the 2nd target drives are OK.
3. put blank disks into the 1st and 2nd and 3rd "target" drives,
If it works, then the 1st and the 2nd and 3rd target drives are OK.
... and so on
If you get a "failure", then you now know which of the "target" drives is the "bad" drive. Either replace that bad drive, or change the cabling inside the unit to "bypass" that bad drive, and put a sticky-label on the face-plate of that drive, saying "do not use this tray".
Oct 16, 2010 | MicroBoards Quick Disc QD-123 (QD-123)...
Machine won't duplicate CD or DVD...A good disk is in source disk area but it reads Source Disk empty or Source Disk not ready....
Nov 07, 2009 | Computers & Internet
It can't read or burn any data on any empty disks (CD-Rom/DVD)! but it can read any other written disks like: programs , Movies , audio disks , data disks just when I put a blank or Empty disk it seems...
Some CD burners are either "+" or "-" or both "+ -".
That said you will have to check what type of burner you have. Example, you cannot stick a "+" blank cd into a "-" burner, and visa versa.
However, if your cd burner can read and burn both types, you should be okay.
Sep 25, 2009 | LG SecurDisc 8x External Double-Layer DVD...
I'm having the exact same problem...
Aug 05, 2009 | Acard Technology (ARS-2030LD) DVD±RW...
Jul 26, 2009 | Acard Technology (ARS-2030LD) DVD±RW...
My dvd writer showing a rewriteable dvd as an empty dvd,but it's not empty..
Its the problem with your dvd disk but not the Drive.
Make sure the disk doesnt have many strikes or dirt.
Normally Re-Writables dont work if they have heavy strikes.
Mar 31, 2009 | HP (344542-005) DVD Drive
DVD player issues
Most likely the dvd is dirty, scratched, or chipped. Try cleaning the dvd disk with a soft cloth (chamois works best). Look at the surface of the disk and if it is scratched lightly, dust and dirt particles, fingerprints, etc will cause refractions from the laser light in the dvd player, which is then read as an error by the dvd player. Cleaning it with a soft cloth will sometimes help.
If that does not work, hold the disk up towards a light source and look for light coming through from the other side. If this happens, the disk is unreadable and unrepairable as the data source has been corrupted.
Dec 17, 2007 | Televison & Video
EZ Dupe (EZD3TDVDNEC) DVD-RW Burner Logo
76 people viewed this question
Top EZ Dupe Computers & Internet Experts
Gene
alwaysreddy
Are you an EZ Dupe Computer and Internet Expert? Answer questions, earn points and help others
