Question about Sharp AR-5320 Black and White Copier
When im parinting or copying something the result is a white paper without any colour what should i do ? and of course the toner is full of black ink
    New Friend:
  • 111 Answers
Check the developer, main corona and the drum
Posted on Jan 02, 2011
Mysterious fluctuation in quality of copies.
fuser drum is bad. photocopier use electricity to transfer the toner to the paper, then it is heat fused to paper. it appears that the problem is occurring around the time that the toner is attracted to the paper.
Mar 07, 2014 | Canon PC-940 Black and White Copier
Xerox printing all black pages
You have no light output. The system places a charge, the image will remove charge (without image processing, the system leaves full charge ) (removes charge where no image is if negative processing)
EX: a copier has platen closed makes a copy because the cover has a white surface the light is reflected and removes charge from Drum. If you make a copy with platen open out put will appear black. Charge was not erased, toner is attracted to charged area.
Most systems use a small wire to place charge, depending on what development (pos or neg) with broken wire will also result in either a black or blank output. I would look for a broken charge wire.
Mar 05, 2014 | Xerox Corporation Xerox ColorQube 8900X...
I have a Canon Imagerunner 1023if and have black smudges along the left edge of paper, both copies and printed directly from computer.
this is possibly a problem in the fuseing part of your machine, where the paper heats up at the back, the fuser roller could be worn out. and your toner could be sticking to it.
Sep 05, 2012 | Canon imageRUNNER 1023iF Black and White...
My FW780 will not make copies. Only white paper comes out after attempting to make a copy. No toner exhibited on the paper. I get no 'low toner' messages or warning lights on the control panel. What...
Check the developer motor maybe the developer is not functioning
or the primary and transfer corona needs cleaning as this cause the hi voltage leakage to ground
so hi voltge is produced results to no copy.
Jan 25, 2011 | Ricoh FW 780 Black and White Copier
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
I HAVE KYOCERA KM-1620 MY PROBLEM IS WHEN I MAKE A COPY THE RESULT IS LIGHT-COPY. ANY BODY CAN GIVE ME ADVICE WHAT TO DO???
Check that you do not have toner save mode (Eco mode)turned on.Also very damp paper can give this result.
Nov 01, 2009 | Kyocera Copystar CS-1620 Black and White...
My printer prints white paper.
check if you have removed paper seal from ink toners.
May 11, 2009 | HP PSC 2175 All-In-One InkJet Printer
My colour print has a white patch
this could be as a result of the machine not being set up for the xerox paper you may need to set up a tray as thisck paper or colour special paper as the machine is running at full speed and needs to slow down for the fuser to be able to work properly on the different paper the toner is not fusing properly to the page. check your paper type settings and if neccessary use the bypass or maunual feed tray.. Good Luck A
Jan 16, 2009 | Office Equipment & Supplies
Too much toner on paper which then smudges
Try reducing the print resolution using the menu buttons. Does it smudge with coloured prints? If so then the fuser unit is faulty. If it is only black that smudges it is likely to be the K Developer unit. Ensure that you are using genuine toners, not refills or third party as the quality of toner can cause similar results.
Jan 14, 2009 | Epson Aculaser C1100 Printer
Error 9-363
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
Sharp AR-5320 Black and White Copier Logo
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
