Question about Microsoft Xbox 360 Console
It has a sitom erro e74. how do you fix it - Microsoft Xbox 360 Console
    Master:
  • 508 Answers
You need to do the xclamp mod they have several videos on youtube. Youll need a universal torx screw driver found at home depot cheap. The xclamp mod consists of thermal compound paste 8 screws forgot whats size and several little washers to go around the screws. And you replace the xclamps with the screws and washers.
Posted on Jan 02, 2011
How do i give my xbox 360 a E74 erroe
Hi there.
The E74 Error is an I/O Hardware Error which could be related to many things. There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. Microsoft covers this error under their 3-year warranty, this is availble to anyone who hasn't modified their console. contact MS to get a free replacement console before attempting to fix this yourself. Failing that this error In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement.
Failing that, unless I'm mistaken are you saying you want to break your 360? Or do you already have the E74 Error?
Jan 06, 2011 | Computers & Internet
When i turn the xbox on it says system error. contact xbox customer service. E74
The E74 error indicates there is a hardware malfunction inside the console. If the console is under warrenty you may want to send it in, but they will send you a replacement refurbished console. If you want to try to fix it your self the RROD fix usually fixes the E74 since the RROD usually follows the E74. Check out this video. I hope this helps,
Thanks and please vote
Oct 22, 2010 | Microsoft Xbox 360 Console
Erroe message on screen "system error contact xbox support
Is there an error code on the bottom of the screen?
E73?
E74?
E68?
E69?
Or another code?
May 28, 2010 | Microsoft Xbox Console
E74 error code for xbox
The E74 error is caused by the scaler chip at the back of the console taking too much heat. To fix it you need to stop the heat build up.
You can do this yourself using a good guide that will show you how to fix it with household items or you can send it in and they will fix it for you.
Feb 02, 2010 | Microsoft Xbox 360 Console
Have a erro E74
e74 or rrod error means that there is an hardware issue.
What you need to do is a very simple and cheap repair.
look on ebay for x clamp repair kits, these are just a few bucks and most sellers include a good guide in how to do the mod/fix.
what causes the rrod or e74 error is the X shape clamp on the underside or the mother board bending and mis-shaping causing the ball soldering on the gpu/cpu slightly melting and forming hairline cracks in the solder.
The x-clamp kit will apply more pressure to the gpu/cpu and a little trick of disconnecting the fans and turning on the xbox and allowing it to overheat will re melt the solder ball joints to fill the hairline cracks.
Depending on which chip is the issue you may also need a 2000 watt heat gun instead of using the over heating method (the gpu chip).
Replacing the heat pads on the heat sink with thermal paste which comes with the kit will keep the gpu/cpu cooler and you wont have this issue again.
Please make sure you buy the kit which comes with heat treated nylon washers as the steel spring washes fail!.
The repair takes around 1-2 hours
I hope this helps in fixing you xbox.
Bewarned that opening your console voids any warranty on it, i would recommend contacting microsoft to see if it is still under warrenty as this could be a free fix by them
Oct 25, 2009 | Microsoft Xbox 360 Console
Xbox 360 E74 Error
Though i fixed the E74 Error myself within an hour but please test the below method at your OWN Risk. Please also note that microsoft is no longer providing Extended warranty for E74 Error.
Check out this DIY Video Guide, that explains step by step instructions to fix E74 Error yourself within an hour. It also provides the money back guarantee in case you are not satisfied. As i fixed my Xbox myself so i thought to share it with you guys....
Jan 22, 2009 | Microsoft Xbox 360 Console
Error e74
99% of E74 error caused by the GPU. you can fix them like the way you fix the 3 red light issue. you can get the repair kit for like $10. I got my from the site below.
Xbox360 Repair kit
Dec 10, 2008 | Microsoft Xbox 360 Console
Erro de sistema contate o suporte ao cliente xbox (mensagem em multi lingua) E74 ( pisca luz vermelha na parte inferior do lado direito)
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
Sorry Only know English but i hope this helps
Dec 19, 2007 | Microsoft Xbox 360 Console
E74 error code
i have found that the same fix for the ring of death also works on this error check utube for details on fix i have preformed this fix on 3 other customers machines with only 1 call back
Sep 23, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
