Question about Emerson Fans Emerson 1052466 1000 Watts Microwave Oven
Enciende pero no gira ni calienta - Emerson Fans Emerson 1052466 1000 Watts Microwave Oven
El plato gira y la luz se enciende solo cuando se abre la puerta con la puerta cerrada el tiempo descuenta pero no calienta
Apparently there is something wrong with the door interlock or possibly the control board.
Mar 30, 2014 | GE Microwave Ovens
How hard is it to change a turntable motor on a micro/convec oven?
Depending on the model, it's not usually that hard. Attacking from underneath, what you will find on many models is atht there is a panel at the bottom that ALMOST looks like you can remove it, but it is ni fact solid and the "panel" is in fact part of the bottom of the machine, linked to it by a few bits of solid metal where most of it is free. Personally, I just snip through the bits of metal. and either make up a screw plate to hold it in place later or (If you are absolutely sure no prying fingers are getting near it) leave the thing off (I DO NOT advise you to do that though).
Once you have access then the motor is usually held in place by 3 or 4 screws and has a convenient plug and socket that you can pull and re-plug the new unit.
Jul 07, 2011 | Sharp R-930AK Convection/Microwave Oven
No calienta
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 23, 2011 | LG LRM1260SW Microwave Oven
No calienta
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Apr 17, 2010 | LG Galaxy Countertop Microwave Oven
Unit will not heat up
check contact points for current. tabs might be bent and are not contacting correctly and no heat the Ni-Chrome wire heats up glow orange when currant is applied , might need a test voltage Meter and screw driver too >^.^<
Mar 14, 2010 | Kenmore Microwave Ovens
Emerson Fans Emerson 1052466 1000 Watts Microwave Oven Logo
Top Emerson Fans Microwave Ovens Experts
William Miller
William Miller
Owen Barnes
 Gary Gemmell
Gary Gemmell
Are you an Emerson Fans Microwave Oven Expert? Answer questions, earn points and help others
