Question about Coleman Powermate Premium Plus 6250W Portable Generator
How do i remove the rotor on a powermate PM 0435001 generator
  • 5,603 Answers
I have heard that you put a bolt in the end of the shaft and use a slide hammer to yank the shaft apart, There is a key, either flat or Woodruf to capture. Some use a length of chain around the bolt and a weight to yank it apart. Be prepared to catch it as it can destroy the windings. Definetly a two person operation.
Posted on Jan 04, 2011
I have a coleman powermate maxa 5000 generator model pm0525312 that needs a rotor assembly replacement. The rotor is not passing a continuity test. The rotor is 5.0 kw rf5 model 0049621.
This shows the rotor as obsolete and I'm guessing the stator would be too. Stators are in the $200-300 price range. Probably better to just buy an new generator. Jack's Small Engine shows some stators but not your P#.
Powermate PM0525312 Generator Parts
https://www.jackssmallengines.com/Products/POWERMATE/Rotors-and-Stators
Sep 30, 2017 | Electrical Supplies
Service manual
Take the through bolt out of the end of the alternator / rotor shaft. it is a long bolt. The shaft from the engine is tapered and unlikely to just pop off. Find a bolt that will screw into the end of the rotor shaft (hardend) find a metal bar that will slide into the rotor long enough so the bolt tightens down on the bar, it will pop the alternator off the tapered shaft
Oct 10, 2013 | Coleman Powermate Powermate 5000W...
Coleman powermate generator won't generate
Check rotor again and measure to see if you have DC voltage on the brushes while running. If no then suspect capacitor
Nov 11, 2012 | Coleman Powermate Powermate 5000W...
How do i separate the engine from generator on powermate 5000
It generally has a long rotor through bolt accessibile from the generator end, this forces the generator rotor onto a tapered shaft on the engine. Once removed the through bolt slide a long bar ion the hole and screw the bolt back in, that will force it off the taper
Oct 29, 2012 | Coleman Powermate Portable Generator...
Need brushes for the generator
please let me know if this provides a solution.
It should. or you should be able to get a lead.
http://sxxiduo.en.made-in-china.com/
Sep 17, 2012 | Coleman Powermate Powermate 5000W...
No output coleman powermate pm401211
Check the capacitor first,check rotor diodes, rotor and stator for shorts, and brushes
Oct 27, 2011 | Coleman Powermate Powermate 5000W...
Colman powermate PM 1500
You could have a shorted diode in the full wave brige for the DC charge circuit, test it with the diade scale on a DMM.
Regards,
Carl
Feb 28, 2009 | Coleman Powermate Premium Plus 6250W...
Generator wont put out enough voltage, only get 107 volts, is this a voltage reg. problem
This problem is either that the engine RPM is too low (most likely), or that there is something amiss in the voltage regulation. Get yourself a DMM that measures Hz, plug it into the output and see if you get 61.5 Hz, if not look for the adjustment on the governor spring. On some Powermates this is a screw that pressed on the governor arm, on others it's a little tab the governor spring attaches to that you bend. Do this at no load. FWIW 61.5 Hz is also 3750 RPM of the engine.
Oct 22, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
353 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
