Question about Velocity Micro Cruz Reader R101 Tablet PC
I turned the Cruz Reader off and I can not get it to turn back on. I tried to charge it but no light will come on. Any suggestions?
Taken from Velocity Micro Support Center:
What should I do if my Cruz device will not turn on?
If your Cruz device will not turn on or freezes, follow the steps below to resolve this:
  • Locate the Cruz RESET location between the Power Button and mini-USB port.
  • Using the straightened end of a small paperclip, insert it perpendicularly into the RESET hole and hold for 5 seconds.
  • Turn on your Cruz
If the steps above do not allow you to power on again, then continue with the steps below:
  • Remove the Cruz from the charger and eject the External SD card.
  • Place the Cruz face down on the desk, starting at the External SD slot, pull off the back cover of your Cruz.
  • In the lower left corner of the back of your Cruz, locate the battery power cable. Unplug the cable and replug it again.
  • Return the back cover to your Cruz and snap it into place.
  • Re-insert your External SD card and power on your Cruz.
Posted on Jan 02, 2011
  • NYer in TX Jan 02, 2011
    Weblink:
    http://cruzsupport.velocitymicro.com/ics...
    Troubleshooter > Support > Model > Reader R101/2/3 > What should I do if my Cruz device will not turn on?
My cruz t301 is froz on the cruz icon
Posted on Dec 16, 2013
My cruz wont turn on after i reset it?
Most tablets are still in the factory settings so if u have a professional to look at it he might be able to turn it on and u could then have him look at the charge thing.
Jan 20, 2014 | Velocity Micro Cruz Reader R101 Tablet PC
How to charge a cruz tablet r102
That happened to me about 2 hours ago. What i did was take the back piece of (be very carefull) and blow into the back. Then Plug the charger in and turn on the power put or oush the power button. It takes a little time because you have to keep trying. If the back is hot take the back cover off and blow on it also. If that doesnt work send me another message or a reply!
May 02, 2013 | Velocity Micro Cruz SE R102 Android Reader...
It wont turn on
When a tablet is completely dead you will need to charge it from a wall plug and not a computer. Also try holding the power button for 20 seconds, it is possibly frozen.
Feb 01, 2013 | Velocity Micro Cruz Reader R101 Tablet PC
My cruz tablet 103 won't keep app open, it just reverts to home page. Any suggestions?
You need to update your tablet, or update the programming on your tablet. Apparently all the android 2.2 tabs are considered "legacy" models and don't support the newest google and java script. Since this is what the net primarily uses, those of us with the Cruz are hosed.
May 13, 2012 | Velocity Micro Cruz Reader R103
Cruz reader t301 will not turn on
I plug my tablet in all I get is the red light on the bottom
I have a cruz t301 can you help me
thank you
john
Nov 16, 2011 | Tablets & eReaders
I was using my cruz when the screen went black! it was a full battery too but now it wont turn on at all....... need help to fix it b/c i love my reader. is there a place or some trick to get it to turn...
This is a "solution" that has worked for a number of similar problems. Try it at your own risk; if at all possible, contact Velocity for warranty support.
1. Place a towel on a table and put the Micro Cruz face down on the towel. 2. Slide a tiny flat head screwdriver around the edge of the back to remove the paneling. 3. Unplug the battery for 5 seconds, then plug it back in. 4. Boot up your Micro Cruz
This is a common solution to the symptoms you described, but you may find you have a more serious issue due to the fact you were using it and it unexpectedly shut off.
Sep 12, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
It will not turn on. and when i plug in to charge, the green light will not turn on.
It sounds like the hardware is damaged. I would try to return in through your warranty.
Mar 01, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Won't turn on - I hit the power button on my Velocity Cruz micro reader to make it 'sleep', but not it won't come back on at all ... what can I do to make it turn on?
Usually when you have what i would call a power lock out. you must remove the battery and wait a few minutes and put it back in, and it usually fires up. Most electronics have these problems. If you are 100% sure the unit is charged with a green light, or no light at all, and you pressing of the top button does not turn it on then remove the back, it is very easy. You can lift it up with your fingernail. If new and faint of heart, under warranty, and all, then make that phone call. Otherwise, you must attempt to remove the connects to the big grey squared battery for a moment, which is said to be easy to do and the battery easy to replace. Look for instruction on the removal on YouTube, or other sites. However, I am more than sure this will solve the problem, unless it has been in liquid, a power surge, dropped, or in excessive heat or cold, or touched by some with "bad karma" for electronics (just kidding). hope this helps.
Jan 02, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Velocity Micro Cruz Reader R101 Tablet PC Logo
5,030 people viewed this question
Top Velocity Tablets & eReaders Experts
steve morris
steve morris
fred capra
fred capra
Are you a Velocity Tablet and eReader Expert? Answer questions, earn points and help others
