Question about Toshiba Qosmio G35-AV650 Notebook
Installed 2-2gb sticks of ram and it is seen in bios but doesnt look as though windows is seeing it. Do I need to upgrade my bios or ???
  • t111hinds Jan 10, 2011
    updated to 3.90 and still in computer properties it is not showing the 4 gig _(new ram) still just the 1 gig. I originally just put in additional 512 mb stick and even though in bios it showed 1 1/2
    gb still not in windows. What is up with this toshiba? Is there a jumper or what on MB?
    Terry
  • 384 Answers
Yes just update your bios
Posted on Jan 02, 2011
I have an eMachine desktop/tower 3230. I need bios upgrade for extra Ram ...
Hello visit emachine here:
http://support.gateway.com/us/en/emac/default.aspx
And select your pc model by number.
Remember to select the right model, because flashing the bios with a wrong one will destroy the mainboard.
I have newer heard that a bios upgrade was necessary to upgrade the ram.
Some mainboards do have a limit of 2gb ram, and the bios upgrade does nothing to that.
Try to clean the pc out for dust, and renew the the cooling paste between the cpu and the cooling element.
One of the ram modules could have a defect.
Try to test one module at the time.
If you get the blue screen of death, the problem is elsewhere like power supply, or harddrive.
Good luck
Jan 17, 2013 | MSI 6714 i845GL Chipset 400/533FSB...
8 GB RAM problems
Windows doesnt like hardware changes. and specially if your useing a 32bit windows it doesnt support more than 3.0-9GB of ram. you need 64bit windows to work on 4GB or more.
Mar 10, 2008 | MSI K8T Master2-FAR Motherboard
Computer does not see all ram. I have 2 of the same 512mb ram sticks it only sees one 512. If I only put in on at a time each one works but not both together. It does not show up in post or windows xp sp2...
u do need to remember that when you use 2 ram "sticks": 1. they CANNOT BE putted in slots directly next to each other. leave slot between them free. 2.they need to be exact same frequency and type [ddr1 or 2 or 3] and they both must have or not error connection on as if bios program upgrade utility is damaged do not try to upgrade bios as u may damage your motherboard beafore u try with 1gb stick refer to otherboard manual for ddr type and momory frequency
Dec 06, 2009 | Computers & Internet
Upgrading ram on laptop, new ram not recognized.
remove the bios battery for a few seconds...and place it back on ...this will make it see the new ram memory modules...if you are sure they are compatible ..they will work .....in fact ..the ddr1 333 512 M is more that compatible with your system and it will work after you remove the battery ...\ my recommendation is to reinstall a clean operation system after you boot up ...and format the C partition too...this have to be done after memory changes to get the max out of them ..
Nov 13, 2009 | Dell Inspiron 1100 Notebook
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
New ram cards to upgrade, now won't run windows
make sure both cards ole & nu....are the same (256mb...sdram...133speed)....and unplugged pc when replaceing battery/memory...have fun playing games
Jul 14, 2009 | Computers & Internet
Upgrading memory to 4GB failure
try to see if that memory is supported with your motherboard. The memory has something to do with that problem.
Jun 16, 2009 | Acer Extensa 5620 Notebook PC
Ram and Bios issue
Make sure your other stick of Ram is installed properly, once that is done make sure that the stick of ram is compatible with that computer. After that even, check to see if your computer is capable of processing that amount of RAM.
Feb 04, 2009 | Acer Aspire™ T180 PC Desktop
Update BIOS for memory upgrade
You cannot change the memory settings in BIOS. All you need to do is go into the bios screen. confim that it has seen your new memory and "save and exit" If it is not showing your new memory try removing and reinstalling the memory confirming it is installed correctly. it should just see it.
Jan 09, 2009 | Dell Latitude D600 Notebook
Upgraded Ram Issues
check the voltage on your new ram.
For ddr2 you need both slots filled.(this the memory I would use)
Make sure you put it in the right slots.
make sure that BIOs recognises each stick.
Let me know if these work for you.
Nov 30, 2007 | EliteGroup P4M800PRO-M478 Motherboard
Toshiba Qosmio G35-AV650 Notebook Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
