Question about Dishwashers
I have a Bosch SHU53513UC/U12 dishwasher. My initial problem is that the washer smells bad after a cycle and I've noticed some water sitting in the bottom of the unit. After running a diagnostic test, it results in a "2" heating fault. I followed your advice and used a current coil to and attached it to the GYBK-a1-3 hot wire on the control board. After running the test again, it only gets as high as 1.15A and manual says it should reach 11A. What should I do next?
  • Dishwashers Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description
I'd say the issue actually with the control...unfortunately. The "2" being displayed in the test is actually an error code associated with a heating fault ( probably the relay solder on the control )
**B/S/H/ also issued a recall on certain models between 1999 - 2006 depending on the model & serial number, you can check with yours since some of the SHU53 series was included for, though it still suffers from the same problem...you'll need the serial number too. Here`s the link if you want to see for yourself **
http://microsites.boschappliances.com/safetyrecall/dishwasher/
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
If you feel capable of checking this on your own, ( sounds like you've got a handle on it ) there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
I have a Bosch SHU53513UC/U12 - dabfa62.jpg
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
This ones new, but it's where to look...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...or takes a long time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning as a result.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further. To add to this, if you want to post your email address I can send you a Bosch service manual.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Jan 02, 2011
How do I fix the heater in my Bosch shu5306uc / u12?
SHU5306UC-12 BOSCH DISHWASHER Manual - Sears ...
www.searspartsdirect.com > Kitchen Appliance Parts > Bosch Parts
Download Manual for Model SHU5306UC-12 BOSCH DISHWASHER.Sears PartsDirect has parts, manuals & part diagrams for all types of repair projects.
Aug 01, 2015 | Bosch Dishwashers
Our dishwasher won't drain completely. I ran it through a regular cycle but it was left with water in the bottom.
Have you tried canceling the cycle? To cancel, turn the on/off switch to on, then press and hold for three seconds the two buttons labeled "Cancel Drain". Keep the door closed for the next minute so that the dishwasher can complete the cycle. During this time the pump will remove any water from the washer. Also you will notice that Bosch dishwashers always leave a little water in the system to keep the seals from drying out and going bad.
Hope this helps
Jan 20, 2013 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Why do dishes stink when they come out of dishwasher?
try running the dish washer on the heated cycle and use a quality wash detergent not ordinary washing up liquid
Apr 14, 2017 | Maytag Dishwasher
Bosch Model shu9925uc/u12 not draining throughout cycle. Dirty, soapy water left in bottom of dishwasher at end of cycle. Help!
ensure filter in bottom of machine is not blocked. if clear
suspect blocked pipe or defective evacuation pump.
i hope this was helpful
Dec 12, 2010 | Bosch SHU9925UC Built-in Dishwasher
Bosch Dishwasher SHX46A05UC/23 - No Water
Sounds like your recirculating pump is clogged If it is water can't get up enough pressure to turn the sprayers.
You'll need to start pulling parts out of the bottom inside to get to that pump. I don't work on a lot of Bosch, but that sure sounds like it to me. I see this a lot. Hope this helps...
Nov 28, 2009 | Dishwashers
SHU43 Bosch Built-in dishwasher
Try running citric acid (3 tablespoons) through.
You can get it from a drug store.
Or, run 1/2 cup vinegar through.
Do this in both the dish washer and the disposal.
After doing this try running some water into the disposal and then see if the next time you run the dishwasher if it still smells.
You could be having a problem with water not staying in the drain trap under your sink that is why if you run water and fill the trap, then you will find out if it was the dry trap that caused the smell from sewer gases backing up into the house trough the garbage disposal.
Apr 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher will not drain - causing moldy odor
Hello Mimhoff it depends on how much water is down there. The sump area always has a little water in it to prevent the circulation pump seals from sticking. Usually around 1 to 2 inches. If there is more than that, check the slots at the bottom of the sump on the left side for being clogged and check the end of the drain hose to make sure it is clear. If you are getting a moldy/odor from the dishwasher, try running Dishwasher Magic or Tang thru the dishwasher. This will remove any build up of food or detergent from the dishwasher. If you are running the dishwasher every few days and just scraping your dishes, then either leave the door ajar or run the rinse & hold cycle to help keep the odor down. Bosch doesn't reccommend running bleach thru the dishwasher as this can cause damage to the rubber seals. However 2 tablespoons of bleach once a year won't hurt.
Feb 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch diswasher
If it is new- then the fishy smell is almost certainly the motor and circuit boards 'cooking' in- most motorized electrical devices have an initial pong. However if it persists after say 10/15 cycles begin to suspect an incipient fault.
May 14, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch Dishwaher shy56a
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
Mar 25, 2006 | Bosch SHY56A02 / SHY56A06 Built-in...
Dishwashers Logo
74 people viewed this question
Top Dishwashers Experts
