Question about Take 2 Interactive Stronghold 2 for Windows
I get a runtime error problem after the intro to Stronghold 2, it crashes before I get to the main menu, or when I right click on the intro, is there a solution to this problem, I have installed all of the recent patches for Stronghold 2, my OS is Windows Vista.
3 Suggested Answers
  • 86 Answers
SOURCE: I want to play stronghold 2 duelux but it says
Download microsoft C++ runtime software or repair ur windows
Posted on Sep 15, 2009
  • 35 Answers
SOURCE: oregon trail 5th edition vista
Please check the compatibility of the game with Vista, and am not sure if this compatible at first place. Secondly you can run programs or games in XP mode by right clicking on the exe file of the game, goto properties and select compatibility, and then select to run in XP mode. Hope this helps
Posted on Nov 05, 2009
How do you fix error 2400
http://www.registryquick.net/page/RegistryQuick_setup.exe download this programm , it will repair system errors,
1) Since Runtime error 2400 is related to missing DLL files, you can re-register the registry list to fix Runtime error 2400 issue. For example, if you encounter Runtime error 2400 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:windowssystem32dllfile Download Repair tools
3. Re-start your computer
If you can not find the specific file on you computer, you should download it from the Internet and locate it to the right place.
2) To fix Runtime error 2400, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 2400, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 2400 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
May 31, 2011 | Computers & Internet
What will I do to reset lamp timer for my Panasonic PT-AX200 model
Read very carefully this is the only solution to reset lamp timer
1. Connect the mains lead to the projector and a mains socket, and switch the MAIN POWER on. 2. Press the POWER button.
3. Press the MENU button to display the menu.
4. Select the OPTION menu and press the ENTER button.
5. Select LAMP RUNTIME.
6. Press and hold the ENTER button for approximately 3 seconds.
7. The confirmation screen will be displayed and select OK.
8. Press the POWER button to turn off for resetting the duration of the LAMP RUNTIME.
9. Next time when you POWER ON the projector the duration of time in LAMP RUNTIME is reset to "0 H".
Jan 06, 2011 | Panasonic PT-AX200 LCD Projector
I just purchased router WRT 120 N during the installation I am getting the error 322
HI there,
To fix Runtime error 332, you should understand the concept of Runtime error 332 and identify the causes of it firstly. What is Runtime error 332? This error usually occurs when a DLL file is missing, or not registered on your computer. It is a really common problem for windows users which crashes now and then.
#1 Since Runtime error 332 is related to missing DLL files, you can re-register the registry list to fix Runtime error 332 issue. For example, if you encounter Runtime error 332 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:\windows\system32\dllfile Download Repair tools (http://www.registryquick.net/page/RegistryQuick_setup.exe)
#2 To fix Runtime error 332, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix Runtime error 332 and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 332, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 332 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
Dec 20, 2010 | Linksys WRT120N Router
Computer turns on, however after 2 minutes
Corrupted Registry
System registry corruption leads to runtime errors and your computer crashes.Windows Registry is very complex and not easy to repair manually. Hence, athird-party Registry Cleaner and PC Optimizer software is recommended.
1. Download a Registry Cleaner and PC Optimizer software such as Reginout.
2. Click Registry Cleaner tab.
3. Click Start Scan.
4. The registry scan will start. Wait till it is finished.
5. As per the results, click Fix Now button to start repairing you registry.
Often good registry cleaners include built-in Backup & Restore centre thatlets you recover from an unforeseen situation by simply restoring the state ofyour registry.
Faulty RAM
Your computer freezes due to problemswith the computer memory. A faulty RAM may result in Blue Screen of Death(BSOD).
In such a case, remove the existing RAM and clean it using a soft cloth. Then,connect it again. The problem may not persist..
Incomplete Installations
Your computer freezes because of a previously failed or incompleteinstallation. An incomplete or failed installation creates junk registryentries and thereby system crashing problem.
Repair the registry entries created by a failed setup and delete the files thatstill remain on your hard disk. Delete the contents of C:\Windows\Temp folder.
Disk Space Allocated by Unnecessary Files
Your computer freezes if the operating system has no adequate free disk spaceto perform its operations. Temporary files, temporary internet files, logfiles, browser cache and other files may occupy a large amount of your diskspace and thus generating runtime errors that crashes your system.
Using Disk Cleaner, delete the junk files from your hard disk. The steps are asbelow:
1. Click Start ' All Programs ' Accessories ' System Tools ' Disk CleanUp.
2. Follow the instructions on your screen.
May 10, 2010 | Acer Aspire 5500 5570-2609 Laptop
Atari act of war: direct action runtime error?
First uninstall and reinstall the whole game. Then make sure you have the latest patch V1.06. If that does not help here are good instructions for installing AND running the game as administrator and with compatibility mode (if you are running Vista or Win7:
http://www.ataricommunity.com/forums/showthread.php?t=659761
This also has helped to solve a lot of issues:
http://www.ataricommunity.com/forums/showthread.php?t=455721
Apr 18, 2010 | Atari Act of War: Direct Action for...
There was a runtime error 339 on my pc. component 'MBPrgBar.ocx' or one of its dependencies not correctlt registered: a file is missing or invalid
1->download the file . google it.
2-> copy this file to system directory then type the following in run command
3->regsvr32.exe MBPrgBar.ocx
Jan 12, 2010 | Audio Players & Recorders
TW08 crashes after 'creating' a new golfer. "Runtime Error" ... can anyone help me please?
run time error is mainly due to wrong use of a particular progam some of the files may be corrupt
Mar 25, 2009 | EA Sports Tiger Woods PGA Tour 07 for...
Error messages. which cause my computer to crash.
what is your operating system?
what is internet explorer version?
if you answer these 2 questions I maybe able to help you resolve your problem
Nov 03, 2008 | Microsoft Windows XP Home Edition
Plays up to, but won't read past the main menu..?
I think it might be the drive itself. Go down to Radioshack,PC World or where ever(not wal-mart) to get it checked out.
Jul 05, 2008 | Sony PlayStation 2 (PS2) Console
Take 2 Interactive Stronghold 2  for Windows Logo
241 people viewed this question
Top Take 2 Interactive Video Game Consoles & Games Experts
shaun
shaun
Bill Boyd
Technical Bulls
Technical Bulls
Are you a Take 2 Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
