Question about Sony FD Trinitron WEGA KV-XR29M80 TV
Have 6 year old Sony Trinitron WEGA KV-HX32 TV - won't turn on, 10 flashes on indicator - what is the problem and is it fixable?
jerryg50
  • 1689 Answers
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
The relay is in the power supply area. I am sure that the fault is not the relay.
It is very common that there are various components starting to go off spec from age. Most of the failures are in the scan amplifiers and power supply areas.
It is also possible that the CRT emission is too low from age. What happens is that it is on the minimum edge and this explains why the set may turn on some of the time.
When the main uPC in the set sees any potential fault conditions it will go in to a protection mode to prevent damage and to be safe. Your set is probably borderline to operate.
Considering the age of your set, I would be shopping for a new TV set.
Jerry G.
Posted on Jul 12, 2008
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
  • 8457 Answers
SOURCE: KV-HX32 SONY WEGA TV
The hight voltage transformer it dead.The FBT(The flyback transformer is dead)The block of plastic with the red wire with a cap hook to the CRT(the tv tube).
Posted on Aug 25, 2009
Testimonial: "Thank you so much"
  • 115 Answers
SOURCE: Sony FD Trinitron WEGA KV-32FS120 timer flashing 9 times
WARNING- VOLTAGES STORED INSIDE YOUR TV CAN KILL YOU EVEN AFTER ITS BEEN UNPLUGGED FOR DAYS..your problem is in the zero cross detect circuit . youu should take it to a repair facility. -Or replace diode D647 . Or on remote in this order press "display -5- vol down - pwr ." and then you could watch it right now ..kinda
Posted on Oct 01, 2009
Testimonial: "Thanks for the amazingly quick response. This is very helpful information."
SOURCE: Problem for Sony FD Trinitron WEGA KV-36HS500 36
ONE: Unplug it for at least 4 hours. That is what we call a hard reset.
TWO: If the hard reset does not help, then it will need further diagnostics.
The following bulletin may be of help in your learning about what is going on. Please refer to it below. Then let me know if you need further assistance.
Have a great day,
Cleggsan
Sony Blinking Codes
Many of the later model Sony TV's have a built in Self- Diagnosis function. If
the timer/standby indicator is blinking, this could be an indication of the
problem with the unit. The diagnostic blinking will occur automatically with no
action required by you to engage it.
The timing of the blinking you see would be as follows: two to eight blinks
(depending on the fault) about a third of a second apart, then pauses for 3
seconds, then the two to eight blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the
number of blinks. The words in parentheses are those which you will see for
each of these faults on a diagnosis screen described later in this article.
Unit is dead and there are no blinks---Problem in the standby power
section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should
show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held
high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this
diagnostic screen. These codes do not reset themselves after the fault is
corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen.
Clearing is done by going into the service mode ( display, channel, 5,
volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
Posted on May 31, 2010
Sony trinitron, about 7 years old, turn it on and picture won't come on for about an hour
Check for bad connections on voltage regulator ic, or bad voltage reg ic in power supply.
Oct 23, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Our problem is that the red light flashes 10 times and then it turns off we can hear sound but cannot see a picture we have turned it on with a friend on an outside antenna and it works but through...
If you were able to get it to work with one signal source but not another, the poblem may be with the foxtel cable rather than the tv. Was there a difference between the connection from the aerial antennae and the cable? Have you checked to make sure another tv works on the cable from that location?
Jul 17, 2008 | Sony Televison & Video
32 inch sony trinitron wega
It will most probably need an overhual of the power supply
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Stand by
I have the indentical tv and problem. Cost to repair was about 250.
Aug 19, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Aug 25, 2009 | Sony KV-32S45 32" TV
The color is fading in our KV-32FV26 Sony Wega The TV is approx 3 years old.
my sont tv model no. KV-XF21M83 (21 in's) indicator lamp flashes red a number of times between 3 secounds interval
the color of the tv has gone faded. The channels name on the top right or left side is not seen properly
The EHT is sparking near the picture tube.
Nessarry guidence may please be comnicated in this regard please. send me feed back to my email adress
sikandher@hotmail.com
Mar 13, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
32" Sony Trinton Wega
Count the flashes and verify that the model is KV-32FS100. The flash count will indicate the circuit in which the problem was detected.
Thanks,
Dan
Oct 28, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
100 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
