I have an antsig AP593 universal remote, i need the code for a toshiba television.
    Problem Solver:
  • 6 Answers
I'm not sure if any of the codes work! But if you want to try the codes again. Put your remote right in front of the point where your TV receives signal (i.e. where you see a light). I used method B - manual searching of the code. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), about 1mm away kinda thing! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working.
Posted on Mar 18, 2011
SOURCE:
I need the four digit code for LG dvd DP152 for my antsig universal remote
Use code search on your antsig URC to find something that works. If a search through all codes stored in the URC fails, you may have to try a different one.
Sep 14, 2018 | LG Televison & Video
What is the code for a Samsung blue ray DVD on a antsig universal remote
The code is in the antsig remote control if it is compatible. Use code search to find out. If a search through all codes stored in the remote control fails, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Jun 15, 2017 | Samsung Televison & Video
I need codes for universal remote for my Toshiba 2006 television
Try these:
TOSHIBA TV 3 Digit Remote Control Codes:
013, 049, 089, 105, 109, 117, 118, 120, 159, 178
TOSHIBA TV 4 Digit Remote Control Codes:
0260, 0358, 0394, 0924, 0398, 0983, 0973
Read more: http://codesforuniversalremotes.com/universal-remote-control-codes-toshiba-tvs/#ixzz3piGVqocr
Oct 26, 2015 | Toshiba Televison & Video
I need the phillips code for my antsig universal remote
Codes to check with Philips are 0592,0879,0729,0629,0197. If you wish to get more codes to Philips brand with different other brand remote controls, check this link.
Feb 17, 2013 | Televison & Video
Antsig AP593 Universal Remote Control Code for Sanyo LCD-40XR10F LCD TV
Hello
Try these codes.
004/ 013/ 049/ 108/ 110/ 180/ 209
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 09, 2012 | Televison & Video
I am trying to use an ANTSIG AP593 Universal Remote Control on a Base DV-360 DVD player, I cannot find a code to use for my DVD player. Can you please tell me a different brand that will either work for my...
This has been answered before on FIXYA. Use the manual search code. Press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light should come on), then hold down "Power" while aiming the remote at your TV. Hold it down until your tv powers off. Then it should be configured and working.It may take several seconds. Then check if it turns on again and if the channels are working.
Feb 02, 2018 | Televison & Video
I lost my lg plasma tv remote i brought antsig universal remote i need the code
These codes work on a LG 4750 with a Comcast three device Remote 11265, 10178, 10700, 10856, 11178, 11758, 11993
1346 ,0008 ,1346
Give credit to adreescheema@yahoo.com
contact No:00923015545637
May 27, 2011 | Televison & Video
I have an ANTSIG AP593 and a BUSH tv I cant get it to tune in....I have tried for two days both the manual and code methods ( a and b).
I used the B method and it worked. But the trick is to really hold the remote right in front..like 1mm away from the point where your tv gets its signal. So wherever you see a light! Took me about 1 minute or more.
Feb 28, 2011 | Televison & Video
Antsig AP593 universal remote
Not sure if you've decided to throw your remote control away already or not. But try using the manual search code. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), and I mean right in front! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working.
Jul 17, 2010 | Televison & Video
Televison & Video Logo
168 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
