I am getting a code 2-2 on my mitsubishi tv model ws-65807. I have unplugged the tv and simulated the problem twice. I seen that you have step by step instruction for the problem, can you please email me at ryanallison03@gmail.com with the instructions?
  • 4,889 Answers
I cannot e-mail you. But I can help you here the 22 error code on this set means "short protect circuit failure". Simply put, you have a shorted component , most likely in the power supply section of the tv, a diode, a voltage regulator IC, fuse has shorted itself. Diodes and fuses are easy to test but thats not the same case with the ICs. If you are skilled in working on electronic circuits and know how to solder, let me know and I will help you resolve this problem.
Sai.
Posted on Jan 02, 2011
Can you easily seperate the top and bottom of the ws 65807 for moving?
Yes. I have the ws-65809, which is virtually the same model. There are 4 rubber plugs that come out on the sides of the TV. under these are four screws. WARNING! You must disconnect the wires connected to the screen before removing the screen or removing the top half of the TV. If you don't the wires will rip out. I believe they disconnect with 2 clips.
May 14, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi 65807 won't power on
hello it's possible the glass fuse may blown inside the tv take the back off and check but make sure the power's off
shaun
Oct 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
I have a mitsubishi ws 65807, i get trouble code 23
The problem is most likely convergence integrated circuit failure. I recommend finding a local Mitsubishi repair center.
Dec 05, 2008 | Mitsubishi WS-65908 TV
Mitsubishi WS-65807 blinks '22'
Jim,
yes the convergence Ics are what cause the two picos to be open they are both 5 amp picos. You can get the picos, the convergence ICs and the factory service manual for your model at the following link.your model is known as the V17 chassis for service manuals and you should require two STK392-570 Convergence ICs. Heres the link they provide free instalation instructions.
http://servicemanuals.vstore.ca/
Oct 02, 2008 | Mitsubishi WS-65807 65" Rear Projection...
BLINKING GREEN TIMER LIGHT, TV WILL NOT COME ON
You can get the repair kit to fix the DM at the following link. Contains the parts and step by step instructions with pictures so you can easilly do it yourself.
Jun 08, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi ws-65807 no sound or picture
Check for coolant spill in corner of signal PC board = from leaky
CRT seal = bad CRT...........................T.
Apr 24, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65807 and blue-ray compatibility
that tv set is only good enough to receive a 1080i signal at the DTV INPUT. unless you can change the output of the blue ray it will be outputting 1080p
Mar 01, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
