Question about Haier HLP21E Top Load Washer
Spin cycles doesn't work, tub full of water
When it gets to the spin cycle it makes a loud grinding type noise and smells like something is burning but nothing is wurning. Any ideas?
I have a similiar problem, mines fills up with water, and the three orange lights start beeping when it suppose to be agitating. please help
Posted on Dec 18, 2008
Did you install the bottom plate yourself? They are tricky and the instructions are a bit unclear - you want the bump side out so that bump goes towards the floor. If you install it with the bump going up toward the dryer, it gets all buggered up. Hope that helps!
Posted on Dec 06, 2008
HLP21E Haier Portable washing machine will not spin and drain water
Posted on Sep 28, 2008
My Whirlpool WTW6400Sw3 is making the loud noise during the spin cycle. There is no water leaking anywhere. I can freely spin the inner basket without any grinding noise or any other noises. Do I need
stator ? maybe? did u check for a foreign object in between the drum and barrel? sometimes a pc of something can get lodged and cause loud noises
Feb 11, 2015 | Whirlpool Washing Machines
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Burning smell loud grinding noise when tilted
Hi there SmartAlec from NelsonVacuums.com.au here. The rattle is the clutch engaging. It can happen for a couple of reasons. The best case for you is if there is something caught in the brush roller that you can simply remove. The next best is that the end caps of the brush are full of junk that you will be able to remove. Its not easy getting the brush out to clean there but it can be done.
If the brush spins in your hand easily when the brush is removed then it is the clutch itself. THe main roller often melts which is caused when the tension on the belt gets to high thus creating too much heat. THis can be resolved only with a new clutch.
Hope this helps, if you have more questions dont hesitate to reply or if you need parts just visit
NelsonVacuums.com.au.
Happy Vacuuming :)
Apr 11, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
When entering spin cycle, making a loud noise. I
Check your belt it may be lose. A lose belt will cause a squealing noise and the machine spin slower or take time to come up to full speed
Oct 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
We have a whirlpool duet washing machine that is about 7 years old. During trhe spin cycle it makes a loud noise. Not the typical "airplane noise." There is also an odor. A burning engine odor. If you...
The rubber belt is worn and slipping under load. (like a fan belt)
There could also be something caught in the belt or pulleys; clear it out and it should work.
If worn, replace belt soon...
Hope this helps!
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer makes alot of noise
time to replace the belt , might need a tub bearing too / tentioner pully might have froze . remove the back panel with the washer unpluged look to see if the tentioner is at its fullest possition if so replace the belt .
Sep 06, 2009 | Maytag PAV2300 Top Load Washer
Haier HLP21E Top Load Washer Logo
989 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
