Question about FUJIFILM FinePix S2500HD / S2600HD Digital Camera
When we try to review it come up "read Error" and dose not let us. also the flash stays on force flash, also wont shut off and freezes up . this all started last night we bought it a month ago and it worked good until then
  • Jeffrey Groves
    Jeffrey Groves Jan 02, 2011
    What is the make and model number of the camera?
  • tbbabe Jan 02, 2011
    fujifilm s2500hd
  • 536 Answers
Sorry, I do not see any firmware updates that apply to your flash situation, but I do see one that seems to apply to your picture review situation:
Please read the firmware update instructions and follow them carefully. Errors during firmware updates can ruin your camera:
http://www.fujifilm.com/support/digital_cameras/software/firmware/s/finepix_s2500hd/fupd.html
Posted on Jan 02, 2011
Sce170a-1a wont harvest
This machine has a cube size control. Which tells the machine when to go into a harvest. there is a harvest switch did you try to force it into a harvest and if you did, did it harvest. depending on ambient temperature from start of freeze cycle to harvest it should be making ice every 15 to 18 minuets and then go into a harvest. so start the ice machine and time it , run it for 18 minuets and force into a harvest. after ice drops check the ice bridge thickness. Bridge thickness should be about 3/16'' the ice dimple must not be DEEPER than 1/16". If this is good then we need to look at what is not working to harvest ice. The cube size control is a reverse - acting thermostat that controls the start of the timed freeze cycle. It must be set properly to prove the correct size cube bridge. When it is closed, an indicator light on the control board will be on. If you force it into a harvest and it harvest the ice with no problems and the ice is at the right thickness then replace the cube size control, but if dose not harvest the ice and you see the ice is at a good thickness and not to thick because if it is to thick it will freeze to every thing and will not drop. SYMPTOM. Unit freezes, but will not try to harvest. POSSIBLE CAUSE: Cube size control will not close; to check: Unplug water pump, switch unit OFF and then ON, in about 2 minutes the timed freeze light on the control board should be ON. PROBABLE FIX: If timed freeze light does not go ON, replace cube size control. SYMPTOM #2: Timed freeze light glows, but after 4 minutes unit dose not power hot gas nor purge valves Then replace control board.
Dec 15, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Toshiba satellite L750-iq6 won't shut down or sleep?!?
That is a software issue with the OS. Was it always like this? If not, try a system restore to some time in the past when you know the unit was working fine.
Sep 06, 2017 | Toshiba Satellite L750 Notebook
Hi. Every time I turn my Toshiba Satellite Laptop on (A305-S6905) it turns on normal then it goes to this black screen and says "A disk read error occurred press ctrl+alt+del to restart." I...
The disk read error message appears when the motherboard can't read what is in the hard disk and use it to launch the Windows boot process.
It means that the hard disk is dead and everything on it is lost, including the recovery partition that new laptops use instead of the recovery disks. You will have to replace the hard disk (a quite complicated job that only an experienced person should do) then order a recovery disk from here
https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp
and use it to reinstall Windows.
Jul 15, 2011 | Toshiba Satellite A135-S2386 Notebook
It beeps then just shut off. When I try to turn it back on it comes on for half a second then beeps and the light goes from green to yellow to a flashing red, and it shuts off and then just stays...
Hi Uniballer,
Are you seeing any flashing red/yellow lights?
If so this is the red light error and you will find that is why the system will not turn on.
Why Does It Happen?
The GPU and the CPU are the 2 main chips in the system and they deal with all of the number crunching however they can get very hot and if they lose connection the system will either freeze up or turn off and give you the red flashing light.
How To Fix?
The key is stopping the heat build up and you can either send it in and they will fix it for you.
Bear in mind that for the PS3 red flashing light error you will be waiting for about 4 weeks and it will also cost you $150 for the repair bill!
Other Ways To Fix?
You can also use a good PS3 Repair Guide to fix it and this will show you how to stop the heat build up with a few household items.
Just make sure that you get a good guide there are some good ones out there!
Click Here For A Complete Review Of All Available PS3 Repair Guides.
Hope this helps and any questions let me know?
Apr 09, 2011 | Sony Playstation 3 (PS3) Console
I got my Wii recently, when i try to insert a disc to play a game, the error message "Error reading on disc, please refer to your nintendo operation manual", the display of this message, i can't do...
forcing the system to shut down won't cause problems. The main issue here is that the laser probably is bad in the drive.
Take a can of air and gently blow some into the drive. This will make sure that there is no dust or dirt on the laser.
Try to a few discs in the drive and if it still doesn't read it then that means the drive is bad and you would need to either replace the laser or the drive itself.
Dec 02, 2009 | Nintendo Wii Console
My Review Toolbar Disappears Everytime PC is Shut Down
On the top menu
tools | customize...
on the toolbars tab scroll down and check the 'reviewing' checkbox. That should keep the toolbar open all of the time.
Dec 25, 2008 | Microsoft Word 2000 for PC
Error 5 ! Canon Rebel Xti w/ 28-135mm It was working fine! had it for 10 day's and after about 560 images taken ( 4 gig flash card ) The message read : "The built in flash auto pop up was...
  • Try the scotch tape or masking tape technique: get around two to three inches long sticky tape, stick about an inch above the flash housing, turn on the camera, hold the remaining tape upward , shoot the camera and pull the tape upward with a force enough to pull-up the flash bulb housing.
Jan 04, 2008 | Cameras
FUJIFILM FinePix S2500HD / S2600HD Digital Camera Logo
228 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
