Question about RCA Thomson Digital Cable Modem (DCM305R)
How to open the NAT for my modem - RCA Thomson Digital Cable Modem (DCM305R)
How to open nat for ps3 modern warfare3
Hey alldayrobbie,
Check out this forum post that gives step directions and has video details on how to open a locked NAT for PS3.
Good Luck
Jul 29, 2012 | Comtrend 12 Used 5361t Modems
How do you bridge a modem ? i have a problem trying to change my nat 3 to nat 1. i have opened my router settings and reset my ps3 settings.i have been told that my problem can be fixed by bridging the...
Bridging the modem actually disables the dhcp server on your modem...
If you bridge the modem, then the dhcp will get disabled which in turn disables NAT on your modem...
If you contact your ISP they will help you to bridge the modem... because bridging varies according to the ISP...
Jan 23, 2011 | Arris High Speed DSL Modem
My router is on, and is hooked up to my verizon modem. My xbox 360 and my computer are both hooked up to the router and all the lights are on but only my computer is working for the internet where my 360...
with verizon, you need to set the modem to full bridged mode so that the connection from your modem will be opened. This certain firewall is called NAT. Your modem and your router has this feature. To disable NAT on your modem, you need to set it to full bridged mode. To disable the NAT on your router, you need to open ports on your router.
You need to open this port on the router for Xbox live to work
TCP: 80, 3074, 53
UDP: 88, 3074
forward it to the ip of your Xbox.
this should set the NAT on your xbox to open, not moderate.
Sep 18, 2010 | Dell TrueMobile 2300 Wireless Broadband...
I need an open nat
The NAT usually has to do with a device connected to a router. You cannot change the NAT on a modem, only a router. To change it to open, you have to simple forward portsneed to contact ur internet service provider for port forwarding.
Sep 17, 2010 | Arris Computers & Internet
How to open NAT on router
To open NAT
On the Windows Desktop, click Start.
2 Select Run. The Run window is displayed.
3 Type cmd /or/ command and click OK.
4 On Command prompt window (black screen) type ipconfig
5 Check the Default Gateway (192.168.?.?)
6 Open IE - on the address bar type http://192.168.?.? enter
It will open the router page
Gateway > LAN — nat config Page
Check Page No 47 on the Manual
Check the Manual
SBG1000 Wireless Cable Modem Gateway User Guide
Enable NAT If enabled, the single HFC IP Address (public IP address) assigned by the cable service
provider is mapped to many private IP addresses on the SBG LAN.
Jan 04, 2010 | Arris SBG1000 Wireless Cable Modem Gateway...
Need to know how to open my NAT for Xbox live with a sb5101 cable modem
192.168.1.0 or sometimes 192.168.1.1
in ur search bar
and then go to advanced setup
and it will say nat settings
then you just click on that and open ur nat
May 31, 2009 | Arris SURFboard® SB5101 Cable Modem
How do i open nat for modem
hi you can enabel the NAT on your zoom modem or motorola router from here
http://www.portforward.com/english/routers/port_forwarding/Zoom/X5/X5index.htm
just select the modem and router and then select the application and you are good to go.
Mar 30, 2009 | Zoom X5 5654 DSL Modem (DH5654)
NAT
The modem is not a router -- your router is what has the NAT not the modem.
Jun 19, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
NAT
Everyone has NAT, whether its strict (which i'm guessing yours is) mederate, or open.
Open NAT can be achieved by buying a new router or connecting your 360 via ethernet to your modem. If you connect it to your modem, restart both the modem and your 360 and you WILL have an open NAT
-Erk
Jun 08, 2008 | Microsoft Xbox 360 Console
Need to change NAT settings for xbox live
Hey, I've had the same problem too with my NAT but it said medium instead of restricted. I havent tried this yet cause I'm at work but you restart your router by just inpluggin the power cord and waiting 20 seconds than trying again.
Hope that works!
Nov 01, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
RCA Thomson Digital Cable Modem (DCM305R) Logo
62 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
shaun taylor
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
