Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Maytag wide by side
The freezer frosted up and both sides got warm. I unpluged it for 4 hrs . When i turned it back on it seem to work fine. this was 4 days agc.
  • Anonymous Jul 15, 2008
    refridgerator not cooling properly and freezer side frosting. Help
You're lucky, these fridge's are garbage!
Posted on Jul 19, 2008
Maytag Wide by Side Freezer not working
open the freezer panel at the back of the freezer section and check the evaporator fan, it could have been burnt.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
The fridge andf freezer is not cold at all
This refrigerator has an adaptive defrost control which has been an issue. You can tell if frost is building up on the back wall of the freezer hence a deferost problem. For an immediate fix, unplug for 4 to 6 hrs with freezer door open, plug in it will work for about 10 days till you can buy this part. It is located in the top back upper fridge side two phillip head screws and 4- 1/4" hex head screws, unplug when installing. It may have to be defrosted again if doors are opened too often.
Jul 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
Fridge side not working freezer frost on back at first now not freezing hardly at all
If you still have the frost build up on the back wall of the freezer, your problem is in the defrost circuit. You'll find a bad heater, terminator or control.
Also verify operation of the evaporator (freezer) fan.
Apr 29, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
My freezer works fine but the refrigerator does not
check to see if your fan in frezzer is working if not u need fan if it. is see if there is frost on back wall of frezzer if there is u have a defrost problem .u can unplug and let thaw with draw open for 4 or 5 hrs will work fine till u get service ther if it is defrost
Mar 18, 2009 | Maytag MFD2560HES Bottom Freezer French...
Fridge not cooling
Make sure your upper fan is working ,its located inside the freezers back wall. If it is running the vent from the freezer over to the refrigerator may be blocked.With out a fan you have no circulation but your freezer may look likes its working,Also if you can pull everything out unplug it turn it down defrost w/ doors open 12 to 24 hrs this will free up any clogged tubes.Turn up to 4 and let it adjust Good luck.
Len West
Feb 19, 2009 | Maytag Refrigerators
Frig not working but freezer is
check and make sure you dont have frost on the back wall of your freezer on bottom and make sure fan is working
Dec 29, 2008 | Maytag MCD2257HES Side by Side...
Maytag wide by side
Sounds like a defrost problem or dirty coils under the machine. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Aug 11, 2008 | Maytag MZD2766GES Side by Side...
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag wide by side.
If it happens again, check the defrost timer. If it does not self defrost, the cooling coils (evaporator) get plugged with ice and although it is frozen, the ice stops the transfer of heat. Unplugging the unit allowed it to defrost so air could circulate again.
Jul 08, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
61 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
