Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
My Samsung DLP HL-P4663W 46 in. turns off every minute and a half. already replaced the bulb, and the timer, lamp, and stand bye flash after turning off.
  • Samsung Master
  • 1,525 Answers
Hello make sure the lamp is fitted securely and the lamp cover as well as there are safety switches. you might have reset the lamp counter hope it helps
regards
shaun
Posted on Jan 02, 2011
  • krimi Aug 11, 2011
    It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Got new bulb and instaled it the tv turns on but the red and green light flashes and no picture
could be the Ballast for the lamp has failed, the power supply board could be defective. can call 1-800-samsung for nearest service center.
Nov 25, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Dlp has no picture only flickering lamp & timer lights.
Verify color wheel is reconnected, color wheel needs to get up to speed before lamp strikes
Jun 21, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Tv will not work
Thunderstorm will damaged the semiconductor such as signal diode, transistor, and IC. Check any shorted component in power supply section. You need Multimeter and basic component testing procedure.
Jun 12, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P5063W
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung 46" DLP
Did you order an ORIGINAL REPLACEMENT LAMP? There's lots of guys out there claiming to sell original lamps but there really not the original. For Samsung TVs (The majority of them) use Philips branded lamps. Check and make sure you lamp is a Philips lamp. Check out FixYourDLP blog for more information as there's lots o interesting reading there
Jun 20, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
343 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
