Question about KitchenAid Dishwashers
Dishwasher will not run. key pad light sensors are on but it will not run. nothing is obstructing the operation and the door is closing and latching. fine.
  • 472 Answers
Could be a few things the touch pad display has a ribbon cable that connects to the pcb or control assemble...the touch pad could be bad /// the pcb(main control) has a fuse in it and they often go bad this reuires taken the cosole apart and removing the screws on the inner door to get it off. if the fuse is not bad you have either a bad pcb or touch pad... before doing all this kill power to unit at breaker for at least thirty seconds and then reset...hope this helps
Posted on Jan 02, 2011
Stops mid cycle and resumes after I push on the door handle
Rather than a problem with the latch sensor it just might be that something is preventing the door from fully closing properly. Check that there are no obstructions stuck on the door/frame seals and that the seals are in good order. Perished seals can prevent the door from closing evenly and this may cause the problems you are experiencing. Also check that the door itself is not warped or out of alignment, this will also cause such problems.
Dec 28, 2013 | Bosch 800 Plus Series SHE9ER55UC 24...
HI,MY DISHWASHER DOOR HAS BECOME VERY STIFF TO OPEN ALTHOUGH IT CLOSES WITH NO PROBLEM. when I looked underneath the door grip handle, there's a little white thin skittle shaped pin .,......when I push...
Hello
Open the dishwasher door and inspect the latch mechanism for obstructions or immovability.
Clean out the door latch with a stiff bristled brush, and apply lubricant. Open and close the door to see if it now latches shut.
Check the door latch and strike plate alignment. Close the dishwasher door slowly and observe the door latch meeting the strike plate. Determine whether the latch is striking the plate correctly. If not, use pliers to gently bend the latch to meet the strike plate.
Gently hammer the latch to better align with the strike plate. Hammer carefully so as not to break the latch or dislodge it from its attached point. Open and close the door to see if it now latches.
Realign the strike plate. Loosen the strike plate with a screwdriver and slightly move its positioning to better align with the door latch. Tighten the strike plate and open and close the door to see the results.
Sep 07, 2011 | Dishwashers
On the display is a flashing CL, according to the manual the latch is not closed. Tried several times to close the door and push the normal wash button. Nothing happens, only the CL light is on. Tried...
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
Nov 26, 2010 | Frigidaire PLD2855RFC Dishwasher
I have a Whirlpool AWM 6100. The light indicating door is open is on, however there is nothing obstructing the door and is is closed? Won't work with this light on, and can't open door!
Very possible the door latching mechanism is faulty because when door is closed the contacts in the switch will see condition is correct for operation and light will extinguish. With power plug pulled out, remove the lid and buy using a small screwdriver try and wedge the doot latch open from the inside. Possibly it will need to be broken off to remove. Once off, door will open then replace with new one.
Aug 05, 2010 | Whirlpool Washing Machines
Dishwasher won't run. Normal light and cancel light flashing cont
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched.The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate. It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
Thank you !!
Jun 18, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher won't start
May 16, 2010 | KitchenAid 24 in. KUDM01TJ - Multiple...
The door won't close completely
Hi, Check for the following whenever you have problems in door
Latch: The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Apr 12, 2010 | Frigidaire Professional Series 24 in....
The door on the dishwasher squeaks terribly. How can this be corrected?
If your dishwasher door squeaks you have to check the following:
Latch
Springs
Hinges
Door seal
If your dishwasher is new or if you have just replaced a door seal the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 10, 2009 | KitchenAid Dishwashers
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Latch problem...?
Make sure nothing is blocking the latch or the door.
Jun 03, 2008 | Kenmore 24 in. 16539 Built-in Dishwasher
Dishwashers Logo
166 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
