Have a fax issue when receiving sometimes my ricoh spc222sf mfd gets a rx com error 200046. Any idea what this means? Any help would be appreciated!
jaylex
  • 417 Answers
SOURCE: Ricoh Fax 3800L Error code
Hi there the error code that you are getting appears to be for the left lock where the fuser is make sure that the door is shut fully and turn the machine off then on again if this doesn't work then it is more likely to be the laser unit and this will need replacing.
Hope this is of some help to you.
Thanks J
Posted on Jan 06, 2008
  • 24 Answers
SOURCE: message error
sir,
You can only receive a fax by pressing *9* from the extension phone which is connected to the fax machine.*9* is an universal code. for more u can read up your user guide.
Posted on Sep 29, 2008
leroyal
  • 2120 Answers
SOURCE: Error on Sharp fax UX-B700
Do you have a DSL or any kind of digital phone line?
Posted on Oct 26, 2008
Ickoajnc
  • 183 Answers
SOURCE: ricoh fax 120 please let me know how to put ricoh
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} - Follow the next instructions to change the reception mode :
1. Press the [F2] key. “ this key is located on the left side of the Control Panel next to the key [12] from the left side and next to the [Memory Trans.] key from the rigt side ”
2. Press the left arrow key to select the reception mode “ this key is located under the Display of the Control Panel”
3. Press the [OK] key when on the display is displayed the mode you want.
note:as you sad you want the machine to reaceive faxes when you are out of the office, so the reception mode [Auto Select] is the most compaible mode for you.
The machine can treat incoming fax
messages and telephone calls in three
ways.
1.Manual Receive
- Use this mode if your line is shared
by a fax machine and a telephone
but you wish to answer all calls
yourself and decide whether they
are fax documents or telephone
calls. You must manually press the
[Start] key to receive a fax.
The machine will ring continuously
until you answer the call, so you
have to be near the machine at all
times. The Manual Receive indicator
is lit when the machine is in this
mode.
2. Auto Receive
- Use this mode if you have a dedicated
fax line. The machine assumes
all calls are fax documents.
It will ring once to alert you of an
incoming call, and then starts receiving.
3. Auto Select
- In this mode, the machine rings a
number of times. You can answer
the call while the machine is ringing.
If you do not answer the call,
the machine automatically changes
to receive fax messages.
Posted on Jul 11, 2009
  • 2072 Answers
SOURCE: Xerox M20i receives faxes but cannot send them?
Is the phone cord plugged into the Line Jack and not the Telephone or ext jack.
Posted on Apr 27, 2010
Can send Fax but not receive error message 0-22 on the fax report
The error message means you have received an fax but there were problems because of poor line condiotions. Ask to resend. Here is lonk to manual.
Ricoh FAX5600L Operator Manual Error Codes
Jan 30, 2015 | Ricoh Aficio Office Equipment & Supplies
SPC222SF IS GIVING ERROR ""PLEASE REBOOT SYSTEM ""
It is in auto reboot mode when a failure occurs. You need to take note of the SC Code that appears before it reboots. That will tell you what is malfunctioning. If it boots up with that - as in immediately - unplug the machine, remove the hard drive, plug in and reboot. Does it still occur? Yes? You need a service tech to check it out. No? Replace the HDD.
Oct 18, 2014 | Ricoh Aficio SP-C222SF Flatbed...
FAX NOT RECIEVING
Have you tried the simple things yet? Have the sender send you one page with a single word on it like TEST.... See if that works.
John
May 05, 2014 | Ricoh Aficio SP C240SF
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Error message -using handset (no handset on the machine. mfd - 1515
If this appear for the first time see the follow, if this started to appear after a time of usage you will need to call a Ricoh technician, sorry but i cannot gain some help in this type of problems.
see do you use a cord with two wires or four for Ricoh when using some telephone centrals like a Panasonic it's better to use a two wired cord for the line, if this still do not help, you will need to call the telephone central technician to set the line for the Ricoh fax.
Nov 17, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Fax error message = TX cancelled:RX fax info mismatch???? Cannot send fax - How do I fix this error - Not all faxes return this message
Two Issues:
1. The Transmission Speed of the MX860 may be too fast.
Solution: on FAX Menu go to Settings>Device Settings>FAX Settings>Transmission Settings >"TX start speed" and change to 14400 or lower (14400 worked for me).
2. The recipient FAX machine may be receiving by a different number than the one you dial. This may occur if you dial a free-calling no.
Solution: Go to Transmission Settings as above>"Check RX fax info" and turn it to OFF. This disables the mismatch issue.
Hope this helps. aknz
Jul 31, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Fax Report Question
i believe it means rx receive and tx transmitt
in rs 232 communication (serial communication modem fax etc) line 2 is tx (transmitt and 3 is receive rx hope that helps
Dec 30, 2008 | Brother IntelliFAX 2800 Laser Fax
Rx comm error 200082 on receiving fax Ricoh aficio 222SF
I have Dell Monolaser MFP1125, can not send and receive fax
Aug 04, 2008 | Office Equipment & Supplies
Fax error code on Ricoh 2045
network errors, like the 15-03, that you are receiving, have to do with fax "forwarding". the errors are thrown because the proper destination, or setup of the destination, for the forwarded faxes, are incorrect.
personally, i have not seen any 15-whatever codes. all the codes that i have dealt with are 14-01, 14-09, and 14-33. please double check the code that you are getting, and check the settings on copier.
14-01 and 14-09 codes usually mean that the smtp server name is incorrect, or the administrator e-mail address has not been added to the setup of the machine. although, it is still possible to e-mail directly without the administrator address being programmed. fax forwarding canNOT work without it. hence, the codes.
14-33 code usually means that there is an issue with the folder destination that the machine is trying to send to.
Jun 27, 2008 | Ricoh Aficio 1035 Copier
Ricoh aficio error message 06-06 page not received
its a fax error that states there is a line problem, problem is probably static in the phone line
Feb 18, 2008 | Ricoh Aficio 1515F Plain Paper Laser Fax
105 people viewed this question
jasbo
jasbo
