Question about Frigidaire GLTF2940ES Front Load Washer
Washer door hinge
The lower door hinge on washer is splitting door will not close
    Novelist:
  • 177 Answers
You need to replace the hinge or have it replaced.
Posted on Jul 09, 2008
I have a Maytag MFW2055YEM Refrigerator. It is a French Door type. The left refrigerator door has a "C" shaped plastic washer that fits under the bottom door hinge. This washer keeps popping out after...
Is there an easy way to disassemble the hinge and put a solid washer? You can make it quickly by cutting it out of suitable useless plastics. If the door is heavy, please use something to fix it open. Another way is to stick the "C" shaped washer very carefully, so that you do not block the hinge, f. ex. with silicone or other not very aggresive glue. Maybe even turning it on 180 degrees after inserting will be enough.
Jan 20, 2014 | Maytag MFW2055YEM Refrigerator
I have a full length fridge and the door seems to have dropped about 1/4", causing the door to bind at the hinge and catch against the adjoining unit on the closing side. What do I adjust and how...
sounds like lower hinge loose or bent down or plastic washer wore out remove top hinge and either move bottom hinge up or shim with washer to raise door
Feb 03, 2018 | Liebherr European Right Hinge Fully...
Left door of the refer isn't closing properly, must manually feed it thru the little channel at the top for it to fold in and close
check the door hinges a in place:
The door latch and lower hinge pin should hold your refrigerator door in place..
Uncover the door by removing the screws.Take the door off and pack bottom hinge with washers and make sure hinge brackets on cabinet are tight.
Check the seal is clean and pliable:
If seal is gapping, one solution is to warm with a hairdryer and pull outwards gently.
Check the refrigerator is properly leveled:
Adjust the middle hinge to straighten the lower portion of the door. Use a level to ensure the door is flush.
After fitting the door back again,check to see if the seal is touching on all sides when the door is closed. If not, you will need a new seal.Refrigerator is properly leveled.and hinges should be properly placed.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 06, 2010 | Amana AFD2535DES French Door Refrigerator
Do the door hinges ever wear out
I did my own search for the same problem and saw Dougs question and lack of a solution. I have the same sagging door problem and was looking for a fix.
First, when I removed the weight of the items from inside the door, the door closes properly. This means that the door is not very sturdy and cannot hold the weight of items placed on door shelving. There are NO adjustment mechanisms on the door hinges either. Bad on Amana. The GOOD NEWS is that I fixed the problem.
Take out all items from the door shelves. I removed the top hinge with the door closed to keep it from falling. I took the door off and placed it on the floor. The lower hinge has a plastic pivot over a steel pin - remove that for a moment. Place steel washers over the steel pin - about .080" or so thickness. Replace the plastic pivot. Replace the door. Add the normal weight of items back on the door shelves. The door closes perfectly. At least until the door sags again and I'll need to add another shim.
Jun 21, 2010 | Amana ABB2524DE Bottom Freezer...
Door leaks water
funny on these washers they used a piano hinge for the upper and lower hinge often they get bent real easliy and sometimes you have to replace the front panel
Jun 02, 2010 | General Electric WSSH300G Front Load...
Right door is lower than the left how do i level doors
if the door is slightly off u need a shim that will fit or a couple of small washers over the lower door pin remove food from door and with help from someone -to help in removing door and replacing it - at the top of the door u will c the upper hinge pin remove cover if one remove the 3 hold down screws while supporting the door remove hinge lift door off lower pin place shims or washers on lower pin till desired height not more than 3/8 is advisable place door on if still to low remove door and remove lower hinge and slightly give it a bend or leave on and slightly bend up hinge when desired height reached replace door and reattach top hinge
Sep 24, 2009 | KitchenAid Superba KSRG25FK Side by Side...
How do I get the top cover off the freezer door and switch it to open the opposite way?
Duct tape the door closed.
Keep all washers and plastic grommets. make screw holes in opposite side accessible IE remove plastic grommets.
Remove the lower hinge remove the upper hinge.Install lower hinge just as it came off and then do the upper hinge. tighten down the hinges then see if the door needs adjusting by opening it and closing it and watching for the door gasket to keep folded properly.
Insert the plastic grommet covers in the original holes and you should be done.
Sep 22, 2009 | Refrigerators
Door must be slammed hard to close.
Do you suspect that the reason the door won't close easily is because of bent door/hinges or some other reason? If it is because of bent hinges a trick is to take an 11/32" deep well socket (1/4" drive) and place it in the lower corner of the door and slowly close. Repeat on other side. This will bend the hinges back to a position where the door will latch easily. If you suspect a different cause, please let me provide me more information and I will try to help you. Hope this helps some and best wishes.
Aug 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dismantling door of Aquarius 1100 WM63P.
Revove all screws from inside of door then it will split with aid of flat screwdriver.
Nov 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Bosch 500 series Front Load Washer Door hanging a bit lower than when purchased
Even if you do not realise it most people lean on the door as they open it, to rectify with the door open but almost in the closed position lift the door by pulling up on the door catch end, this will straiten the hinge, very common problem Regards Engineer
Jul 26, 2007 | Bosch WFMC 3200 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
147 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
