Question about Garmin StreetPilot c530 GPS Receiver
While plugged in, my Garmin c530 will shut down immediately after it says "loading maps". Why is this?
  • 321 Answers
This problem only comes up when the battery is not properly charged, therefore not being able to power up the gps beyond the loading map page. Try to reset the unit by holding the power button for about 15 seconds, it will restart the unit, once it restarts it, check if it will get pass the loading map page. Then you try to back up the software on a computer, format it and restore the software back on the unit. If that does not help, then you carry out the following tests.
Try to charge the gps device for about 2 hours then try to turn it on. If it does not come on, then it means the battery did not get charged. That can be a problem from either the battery or the charger or the charging port.
First test the battery by fixing it in another gps and charging it for about 2 hours then turn it on. If it powers on the gps, then it means the battery is okay, but if it does not turn it on, then it means the battery is weak and cannot hold a charge and the solution is for you to replace the battery.
Next you test the charger by trying it out on another gps device, if it turns it on, then it means the charger is intact but if it does not turn it on, then the fault is from the charger.
Finally, test the gps itself by trying to charge in by connecting it to the computer using the USB cable, then you turn it on, if it does not come on, then it means there is a problem with the connection port or there is an internal problem or something with the unit.
Hope this advice was useful to you.
Posted on Jan 02, 2011
Comes up "No detailed maps
I had the same model of Garmin that you currently have now. I would only get that message when the maps were not current. You can go to Garmins website and they will sell you the current CD with all of the current maps for your area. You install the CD on your computer and then connect your Garmin with a USB cable to your computer and it will then download the latest maps on to your Garmin unit. Garmin updates their maps once or twice a year I think. Go to www.Garmin.com to see the pricing for the current CD for your area.
I hope this helps you out
Apr 01, 2011 | Garmin StreetPilot c530 GPS Receiver
I have a garmin street pilot c530 after i power it up and agree to the disclaimer the screen reads as follows no deailed maps found that support routing street pilot cannot be used without them the unit...
I just purchased my c530 a couple of days ago and had been loving it. I had added some custom POI's to my sd card using POI loader version 2.4.0 and that had worked fine. Then the other day I tried to load some new custom POI's, but POI loader got hung up and froze. After disconnecting the c530, I restarted it. After it started, a screen came up that said "No detailed maps found that support routing. The Streetpilot cannot be used without them." I contacted garmin, here is the site for contact info since I am unsure where you are. http://www.garmin.com/garmin/cms/site/us/support/supportcontactand the tech support at Garmin. They said that somehow the files on my c530 must have gotten corrupted. The person I talked to at Garmin was very friendly and walked me through several things trying to get my unit to work. He was very apologetic and said that this should not have happened. He told me I would have to return it and get a replacement. Sorry Hope this helped.
Jun 09, 2008 | Garmin GPS
Free garmin c530 map updates
I don't think there is one.  I had to buy an $80.00 CD-ROM for mine.
I did find an article about this here: http://www.gpsmagazine.com/2007/08/garmin_map_update_not_so_smoot.php
Sep 05, 2009 | Garmin StreetPilot c530 GPS Receiver
Freezes on the loading maps message
Hook up your Nuvi to your computer and go to the Garmin site and download the latest driver software to the 680.
Jul 08, 2009 | Garmin Nuvi 680 GPS Receiver
Streetpilot c530 will not stay on,shuts down prior to loading maps.
battery is sogged and needs replacing or recharging on AC source
Jun 20, 2009 | Garmin StreetPilot c530 GPS Receiver
Garmin c530 powers up breifly then shuts down
The problem is with the battery, DC will not fully charge the battery to its required capicty to work. You need an AC charger and to charge it fully ( 10 hrs Max) and then try it. It needs a lot of power to drive the screen and connect to satellites.
Invest in an AC charger and all should work properly
Jun 07, 2009 | Garmin StreetPilot c530 GPS Receiver
Deleted memory for garmin c530
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. This would allow your to install new maps. You did not delete your internal memory, you deleted your internal maps. Moving the maps from internal to external memory cannot be done on your PC and have them work. They have to be installed on the SD card via Garmin Express. https://support.garmin.com/faqSearch/en-US/faq/content/b17m7lCO3R4UKUAt8x67J7
Mar 21, 2017 | Garmin StreetPilot c530 GPS Receiver
Maps are missing
Same here..the phone support sucks.. i am on hold right now for 20 mins and i am not sure if they have an answer!!
Jun 01, 2008 | Garmin StreetPilot c530 GPS Receiver
We would like map updates for our c530 garmin
Map updates are available for purchase either from www.garmin.com, or from a local retailer that carries Garmin GPS products.44802
Apr 30, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin c530
According to technical support, the "glitch" has been fixed with the latest web updater on the Garmin site. In the meantime, you will need to leave the unit unplugged for upto 48 hours to allow the battery die and the unit to get out of its "hang up". Once the battery is completely dead, plug the GPS into a computer (USB) and it should come back to life. Then do the update.
Hope this helps.
Nov 02, 2007 | Garmin StreetPilot c530 GPS Receiver
Garmin StreetPilot c530 GPS Receiver Logo
260 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
