Question about Nikon Cameras
Error code 'CHA' on the D70 - Nikon Cameras
  • 3,083 Answers
The following web blog says the error is due to the camera not being able to write to the card:
http://www.dgrin.com/showthread.php?t=79691
It also looks like the error could be linked to the battery, and charge therein.
If you google "nikon d70 cha error", you will find some blogs that talk about the problem. Hopefully, they will help you figure it out.
If nothing helps, contact Nikon:
http://www.nikonusa.com/Service-And-Support/index.page
Good luck, and hope this helps.
Posted on Jan 03, 2011
  • Jazzajon Aug 05, 2014
    Probably your card has become corrupt. First try reseating the card in the card reader. Push it in hard. Do this with the camera power off. Now try turning the camera back on . Try this a few times. If this does not work try reformatting the card firstly by using the camera. Re formating should take a few seconds if shorter than that there is a problem. If that does not work reformat using a PC.
What does the error message CHA mean on a Nikon D70?
It means it can't read the memory card. Try formatting it. If that doesn't do it, try a different card.
Jan 04, 2011 | Nikon D70s Digital Camera
Nikon d70 keeps popping up with "CHA". Wich means
You could try formatting in on PC by right clicking the card's icon in My Computer to bring up the options, then format it on the camera as well
Dec 16, 2010 | Nikon D70 Body Only Digital Camera
CHA flashing on readout screen. Battery is fully charged. What does CHA mean?
If there are brackets around the CHR, it means the card is locked. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If there are no brackets around the CHR, it means the camera cannot read your memory card. Try a different card.
Dec 12, 2010 | Nikon D70 Digital Camera with 18-50mm Lens
My nikon d70 keeps saying (CHA) and will not let me take photos and deleted the ones I did have this is my third card please help
Sccording to my D70 manual:
"CHA"= this card cannot be used. try Nikon approved card,, Try reformatting card in camera, not PC, clean card contacts in camera using camel hair brush and blower.
You might also use a small pen and press the hardware rest buttin in bottom of camera (page 200 in manual)
Nov 12, 2010 | Nikon D70 Digital Camera with 18-50mm Lens
CHA display were the counter numbers are
CF Card reading error.  Usually cheap cards, can be bent/tarnished/worn pins inside D70, this part can be replaced.
First read:
http://www.vandyll.net/?p=499
Then read
http://www.stephanmantler.com/wordpress/d70s-camera-repair/en/
Nov 14, 2009 | Nikon D70s Digital Camera
I have a Nikon D50 with an error message "CHA"
This error indicates the following:
This card cannot be used (CHR) blinks.
Problem(s)
Error accessing memory card
Unable to create a new folder (on card)
Card has not been formatted for use on D70
Try another card
Format the card using your D70 (all images will be erased)
Check the card for visible damage or poor contacts.
You may have inserted a memory card that was been used in a different camera or the formatting process did not complete successfully.
I hope this helps.
Jan 30, 2009 | Nikon D70s Digital Camera
Nikon D70 digital camera memory card cannot be used
First read:
Then read how, with pics:
Careful now....
Dec 09, 2008 | Nikon D70s Digital Camera
Nikon D70, displaying error code 'CHA' when memory card inserted. Unable to format or use memory card. Have tried new memory card, still same problem.
CHA errors indicate a communication issue with the CF card. Your card could be going bad, you could have a broken pin, or any number of other problems.
I'm running into this same problem now. If anyone has a good step-by-step to troubleshoot which of the dozen things this error could be, I'd appreciate it.
For myself, I'm planning to start by trying a new CF card.
Sep 02, 2008 | Cameras
Problem with Nikon D70
The error code "CHA" is telling you that the CF card you are using for storage is not compatible with the camera. You should consider trying a different card, perhaps a slightly older one that is not as fast.
I use a SanDisk Ultra II card, and that works fine for me.
Dec 10, 2007 | Nikon D70 Digital Camera with 18-70mm Lens
Cameras Logo
99 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
