Question about Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Natural Gas
Spa heater turns on and shuts down before spa heats up. what is the problem?
    Problem Solver:
  • 5 Answers
Could be a dirty filter not enough flow of water,pump could be sucking air ..do not adjust the pressure switch ..as last resort take pressure swich out (its attached to copper tube in the front and make sure its not clogged ...best bet is pump problem sucking air or dirty filter good luck www.dollarspa@aol.com
Posted on Jan 02, 2011
Why does my pump want to shut off after I enable the heater?
before turning to spa dis able pool heat then try if same happens need new PCB control board
Jun 01, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
I have Jandy/Zodiac LRZE legacy heater and Jandy RS6 controller. When hooked up to RS6 and there is a call for pool heat the heater ignites but shuts off in about 30 seconds. When I disable the TSAT...
check your dip switches on the inside panel of the aqualink if you still cannot get it to work i would use the pool to 1 wire of a new wire you will run to the heater then 2nd wire to com then on the on the PCB board going to pins 1 and 2 of the big plug then turn heater all the way up when heater button is pushed or activated it will turn heater on and off
Aug 05, 2013 | Jandy Legacy LRZ Heater
Dream maker spa x-400 won't shut off keeps heating. I have turned it off and let it tottaly cool down the temp max temp is set to 95 and it never shuts off until it gets to 105 and overheats.
I had the same problem last year, I talked to a spa guy and he stated that the temp sensor was probably covered in bio crud. He also stated that the tub should be cleaned with a hot tub flush. After doing that I have not had a problem with the temp settings.
Jan 19, 2013 | Pool & Spa
Pool heat not turning on
Sounds as If it is electrically heated if so you have a heating element out. The board senses it and shuts it down. It could be a programing problem i have provided the manual for it below is the link.Remember to rate my solution and leave testimonial it is how i earn my accomplishments Thanks
http://www.pentairpool.com/pdfs/MiniMaxNTHeater-DDTC-IG.pdf
Apr 22, 2012 | Pentair Minimax NT Heater
Same Issue
the pump stop so will not drain spa dip # 4 may turn off for the delay but not sure if the pump will still turn off since this is new tech. good luck
Jul 05, 2009 | Jandy Aqualink Rs4 One Touch Control...
Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Natural Gas  Logo
140 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
