We have a Whirlpool WFS1273AW 7.5kg front loader. This morning it finished its 40 degree cycle and the clothes were still dripping wet. We put the machine on to a spin only cycle and it counted down from 18 minutes to 14 as usual then it stayed on 14 minutes repeating the same actions. The pump light is not on and no error codes are showing.
  • 2 more comments
  • tdruery Jan 02, 2011
    I ran another load through - there was no water left in the drum. I ran it at 1000rpm spin speed and it went through fine. It seems to be at 1200 that there is a problem. I will check the pump but the warning light hasn't come on.
  • tdruery Jan 03, 2011
    There was a piece of leather watch band and a bobby pin that were not stick but I am guessing they were bouncing against the impeller when the spin cycle was on its highest speed. too big to go into the blades and block it completely. Thanks.
    Clear and accurate advice. Problem solved. Thanks.
    Part of a leather watch band and a bobby pin were in the end of the drain pipe near the impeller. Too big to go through and jam the blades but big enough to impede the impeller at high speed spin settings. Thanks
  • 1,998 Answers
If the water is still in the drum and you can hear the pump engageing then you would have something either caught in the pump or in the drain line. If they pump is unable to push the water out the drain line then the water will stay in the tub best thing to do is remove the bottom panel and have a shop vac and a small pan nearby disconnect the two hoses that go to the pump and see if there is anything caught in the pump or in the lines put the pan under where you seperate the hoses and turn on the shop vac to **** up the water this way no water on your floor and when you undue the clamp on the hose dont just pull of the hose slowly take off the hose so it leaks into the pan slowly here are the steps to checking your pump and hoses
Pull both hoses off the pump and check for any item causing a slow pump out
1. Unplug the washer
2. Take of the toe panel in the front by removing the three screws.
3. Get a bunch of towels (I mean a bunch!!!)
4. The pump is in the center, and it has a plastic grip handle that one can unscrew to remove the filter. As you unscrew it, LOTS of water will come out. Be ready with the towels. A cookie sheet helps to collect the water too.
5. Clean the filter assembly.
6. If one wishes to check the inlet of the pump, remove the back panel, about 12 screws. (Note, the following works for replace the pump as well)
7. Remove the large bellow from the bottom of the tub that goets to inlet of the pump by removing the clamp
9. Lift up on the plastic cover that covers the wires that power the pump. There may be a small plastic catch that is lifted up as to allow the connector to become free.
8. Remove the Torx screw that holds that is the center just under the filter screen.
9. Pull the pump forward.
10. Unclamp the pump outlet hose.
11. Remove pump
12. Unclamp the large bellow on the pumps inlet and inspect for debris.
13. Clean pump and fitler w/o getting water on the pump.
14. Install in reverse order
if you have any further questions please message me back and please remember when our chat is concluded to rank how this opinion has helped thanks again Rick
Posted on Jan 02, 2011
  • Rick Ead
    Rick Ead Jan 02, 2011
    sometimes the light wont come on check the pump and the lines and get back to me with your finds Thanks again Rick
  • Rick Ead
    Rick Ead Jan 03, 2011
    excellent great job on the repair have a Happy New Year I would ask if you would like to write a testimonial but it seems alot of people dont know how to on here in fact neither do i still waiting for staff to write back on how to but thank you again Rick
Whirlpool front loader WFS1273AW why is thewater continuing to run during cycle
If it's only on one cycle it is a controller fault giving the inlet solenoid power all the time. This would be very unusual. It is more likely to be something in the inlet valve allowing water through.
Apr 21, 2012 | Washing Machines
Whirlpool washing machine WFS1273AW manual
I have a whirlpool WFS 1273 AW front loader that gets stuck in the spin cycle. The timer counts down from 18 minutes to 17 minutes and starts to spin but before it gets to full speed the control panel lights all flash, go blank, and the. The timer resets to 18 minutes. I have cleaned he drain pump, removed the clothes and tried it when empty and it does the same thing. It does not appear out of balance.
Jan 04, 2012 | Whirlpool Washing Machines
Clothes are too wet when finished washing. water drips from clothes.The spin cycle seems to be spinning as the clothes are against the outside wall of the tub. we have the extra spin cycle used aslo and it...
Transmission is bad. Buy new washer. Best brands are (Kenmore, Whirlpool, Maytag).
Thanks and Please Rate me! Tips provided by www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | GE WPRE6150HWT
Water left in machine (clothes dripping) after delicate cycle
Whirlpool is best in the standards of top loading washing machine when you are going for the front loading you can buy the IFB washing machine to get the better result
May 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Washing cycle on a 40degree op. takes more than
Don't forget that the reason you bought a front loading washer is for the efficiency of the washing. In other words, front loaders use less water and get clothes cleaner without all the harsh beating that the older agitator units do.
If you're using any of the pre-programmed wash cycles, you might want to tgry another cycle to see how it does for getting your clothes clean with a shorter cycle.
If you check your owners manual, it should provide the cycle times for the various wash and water temp settings. The colder the water you use, the longer the wash cycle typically is, since it takes more agitation and time to get clothes clean, especially with front loading machines. Hope this helps.
Jul 28, 2009 | Whirlpool WFW9200S Front Load Washer
Can't see water level at all
Yes very normal in a front loader for clothes to be dripping wet but you may see little to no standing water.
Nov 02, 2017 | GE WBVH6240F Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Not washing clothes
Sounds like you need a new timer.  Sorry.
Oct 14, 2007 | Zanussi IZ161S Front Load Washer
Open Questions:
Washing Machines Logo
347 people viewed this question
Top Washing Machines Experts
