Need replacement screen for model vs 50803 mitsubishi big screen tv
  • 13433 Answers
SOURCE: MITSUBISHI TV VS-60607
Do you get any power indicators? it may be a problem in the powersupply area, or something more serious. Start with checking the fuses there.
Posted on Jun 07, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi big screen model VS 60601 convergence adjustment
you need new convergence ICs. If you can respond to this same post and verify the model number of your mitsubishi, I wll post the correct ICs that your model needs.
Posted on Aug 17, 2008
jomabug76
  • 1148 Answers
SOURCE: VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Posted on Oct 05, 2008
SOURCE: MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Posted on Nov 25, 2008
  • 18 Answers
SOURCE: TV is lock
Using the Mitsubishi remote, go to the locked function and when it asks for the code pres QV and 9 at the same time on the remote, this will work in any mode which may be locked, including entering a new password!
Posted on Jan 04, 2009
Mitsubishi VS-50803 Big Screen TV - Trying to hook up an HDTV cable box, I was told to hit: menu, 1, 3, 7, 0 - to get to the service menu and switch DTV over to HD and that would solve my no signal...
First please confirm actual model number on rear of set.
Something is not right here, I am looking at Mitsubishi material downloaded in my computer; shows all codes for sets up to 2004. VS-50803 is a VZ6 Chassis made in 1998 and I doubt it is HD set, if it is one of the early ones it will have beneath the HD input vert sync and Horz sync---those required a special box from Mitsubishi etc.
Set has 3 hidden menus:
1. Option menu (for hard reset)= Menu 1,3,7,0 enter
2. Circuit adjust menu= Menu 2,3,5,7 enter
3. Convergence adjust menu= Menu, 2,3,5,9,enter (#4,5,6 on remote then change modes)
Does the DTV input have the two vert, horz jacks as well?
First is the Option menu is really only for a hard reset of the entire set, if you engaged it you may have de-converged the set.
The adjust menu is for height, width etc
The convergence menu is for convergence.
If you did something and did not save it, unplugging set should put it back to before what you did.
In the OPTION MENU WHAT DID YOU SELECT AND DID YOU HIT ENTER WHEN YOU FINISHED?
STEVE
Oct 08, 2011 | Televison & Video
I have a 50803 projection tv. The picture went out. It started with a green tint and lines going across it. I turned off the tv and then turned it back on. Now there isn't any picture at all. There was...
This is very simple to repair if have burning parts smell,replaced parts that burning smell,the parts that cause by the burning smell part,make it to dies that hard to find.My sugestion replaced the DM power board,first to get power back,than go on from there.
Dec 12, 2009 | Mitsubishi VS-50803 50" Rear Projection...
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
50" MITSUBISHI BIG SCREEN (MODEL#VS-5076,
INITIALIZE THE SYSTEM CONTROL. WITH THE REMOTE CONTROL PRESS "MENU 2, 3, 5, 8, " USE THE ADJUST BUTTON TO SELECT "INITIAL" AND PRESS "ENTER"
Mar 17, 2008 | Televison & Video
Mitsubushi Big Screen TV Screen Protector vs 60601
that will have to be a dealer orderd item.. Unless you can find one used. I would try the tv shops in your area , they may have a used mitsubishi screen
Jan 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi big screen tv
Do the self test first find the error code. Look on here or ctechnicians.com
Jan 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Big Screen TV not working
Check your video input cable or replace, maybe it is damage if not Video chip problem etc
Dec 16, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
